The "What Did You Work On Today" thread - Page 270 - Hot Rod Forum : Hotrodders Bulletin Board
  #4036 (permalink)
Old 06-17-2013, 03:43 PM
1971BB427's Avatar
Had my first drive in the Falcon today. Lasted about 15 min. and everything worked good, shifted good, and steered/stopped well. Then just as I got right to my house the carnage began! The outter ring on the balancer came off, and shot out the side, right into my parking strip! Somehow it missed everything on the car, and only put a mark on the water pump pulley.
Of course I thought the whole engine had come apart, so it was pretty scarey at the time, but looks like a new balancer is all it needs. I think it had issues before, as I was checking TDC when I installed the cam, and noticed the mark was off about 45 degrees. I called around and did some searching, and found out there were 3-4 different timing marks on 454 balancers, and was assured it was just a wrong mark for my engine. I filed a new mark, and installed timing tape. Looks like maybe it wasn't a wrong mark, but a balancer outter ring that had already spun a bit.
I've got a new one coming from the local performance shop tomorrow, so I'll get it on and hope all is well after that!
  #4037 (permalink)
Old 06-17-2013, 03:53 PM
1971BB427's Avatar
Deleted-double post.
The Following User Says Thank You to 1971BB427 For This Useful Post:
MARTINSR (06-17-2013)
  #4038 (permalink)
Old 06-17-2013, 03:57 PM
YEOW! That's something that can cause some damage!
  #4039 (permalink)
Old 06-17-2013, 04:07 PM
1971BB427's Avatar
Yes! I've had friends who had balancers explode, and it usually wasn't pretty! I am pretty lucky it happened at home, and just came off in one piece! It's wall art now, and a reminder of what could have been very ugly!
  #4040 (permalink)
Old 06-17-2013, 05:06 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Your lucky with that balancer ,sounds like some one might have cleaned it with carb cleaner ,,I ruined mine that way carb cleaner swelled rubber and made it soft ,bought a fluid damper and timing mark was off like yours had to remark it,my original timing mark was at 12 o cloch the new on was at 2 o clock,
gooid to hear you got to drive it.
  #4041 (permalink)
Old 06-17-2013, 05:31 PM
BOBCRMAN@aol.com's Avatar
Be sure to measure the ID of the new balancer. Most of these are made in China and a China inch isn't the same as an american inch.. The balancers tend to be too tight and will split down the keyway when installed. Then BANG there goes the radiator,, seen it happen (or the results) a couple of times!!
  #4042 (permalink)
Old 06-17-2013, 05:32 PM
Glad you dodged the bullit. That would be scary!
John
  #4043 (permalink)
Old 06-17-2013, 06:02 PM
Today was a good day. I really enjoyed playing in the basement today. Rusty is coming together though a little slower than I would like. The good thing is, I now know what I am going to do so it is just a matter of doing it.
John
  #4044 (permalink)
Old 06-17-2013, 06:35 PM
Built Not Bought
John
Seems every one is moving fast on there projects,most of you stared months after I did and are farther along ,great work to all,,wont get to work on mine for a while got to go to DR Jeckel tomorrow.
  #4045 (permalink)
Old 06-17-2013, 06:37 PM
Last journal entry: door trim
fathers day
On Saturday I got my fender back for the my friends shop, he fixed the dent and matched the primer he did early. Put it on and installed the tail light and wiring. sunday was the car show at our local auto and air museum. Nice sunny day for a fathers day finally. Had my car inspected by the NSRA inspection team at the show for the first time and it passed. pretty happy about that. Back to mowing lawns tonight. SC
  #4046 (permalink)
Old 06-17-2013, 06:39 PM
1971BB427's Avatar
You may be right David. It was soft when I examined it. The timing marks on my BBC are at 2:00 also. I will need to get new gilmer setup. I pulled it all off, and also the balancer. The water pump pulley is out of round, and can't get just the one pulley.
Thanks for the tip BOBCRMAN! I'll check it with my calipers to be sure it's not going to go on too tightly! The old one went on pretty tight, but looked original style.
  #4047 (permalink)
Old 06-17-2013, 06:42 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Hey. You use the same code words that I use when I have to talk to my wife.
  #4048 (permalink)
Old 06-17-2013, 06:46 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Got the brackets and pulleys mocked up.
I need to drill and tap a hole in the head though.
Name:	DSC01660 (Medium).JPG
ID:	74975   Click image for larger version
Name:	DSC01661 (Medium).JPG
ID:	74976   Click image for larger version
Name:	DSC01652 (Medium).JPG
  #4049 (permalink)
Old 06-17-2013, 07:02 PM
I see the belt is loose Pugs. What tightens it up?
John
  #4050 (permalink)
Old 06-17-2013, 07:05 PM
Built Not Bought
Check with ASA performance Columbus Ga on web,/ ABAD71CAMARO.on ebay
it is the same company ,I think they sell individual parts .
build thread, projects
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
cgates
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
