The "What Did You Work On Today" thread - Page 272 - Hot Rod Forum : Hotrodders Bulletin Board
  #4066 (permalink)
Old 06-18-2013, 01:54 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by 123pugsy View Post
Got the brackets and pulleys mocked up.
I need to drill and tap a hole in the head though.
These install with 1 long bolt in head and 2 in water pump very sturdy ,the one on my engine came with bracket ,SSbolts,SS turnbuckle for around $50 from ASA performance.
ID:	74993   Click image for larger version
Name:	ac bracket.jpg
ID:	74994   Click image for larger version
  #4067 (permalink)
Old 06-18-2013, 02:01 PM
Built Not Bought
This is a better picture o install.,this might or might not be some thing you would want,it has about 4 in of adjustment.
  #4068 (permalink)
Old 06-18-2013, 04:30 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by Too Many Projects View Post
If the hole goes into the oil return galley, you'll be OK. I've done that in a pinch (read screw-up). If you can only drill 1/2" near the combustion chamber, you'll only get a couple threads. The drill bit has the point taper to contend with and then a tapered tap will barely start that shallow. A bottoming tap will get threads down near the taper but it still won't be more than 3 threads on a course thread bolt. I would be concerned about it holding for long.
I see another threaded hole in the head near the exhaust. You could make a triangulated bracket and use both those holes for rigidity and strength. It would appear like another Allen Grove bracket... I have his sets for my alt, ps and a/c comp too. Looks like a puzzle when I opened the boxes...
Yep. Alan Grove brackets. They're not bad. I ended up adding a bracket to the front header bolt.
Thanks.
  #4069 (permalink)
Old 06-18-2013, 05:45 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by 1971BB427 View Post
You may be right David. It was soft when I examined it. The timing marks on my BBC are at 2:00 also. I will need to get new gilmer setup. I pulled it all off, and also the balancer. The water pump pulley is out of round, and can't get just the one pulley.
Thanks for the tip BOBCRMAN! I'll check it with my calipers to be sure it's not going to go on too tightly! The old one went on pretty tight, but looked original style.
Definitely need to check it. I had to buff out an aftermarket damper for a guy's 454 Monte Carlo. It wouldn't even start on. I buffed it out with a small flapper wheel on a die grinder, to where it went on the first inch or so, without a lot of trouble. Still had to drive on it with a block of wood and a shop hammer and finish it up with the bolt.
  #4070 (permalink)
Old 06-18-2013, 05:58 PM
Built Not Bought
Thanks.
I should have thought about that since my 327 has on on the other side for P/S since there are no holes in heads (camel humps) it also hooks to front two exaust bolts and a t bracket.
  #4071 (permalink)
Old 06-18-2013, 06:03 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Hmmmm.........blower motor now ...
Wrong crankshaft, rods or pistons ??
I thought .028 down the hole was pretty much a stock set up. Am I wrong ? Sounds like regular rebuilders pistons. Allows for decking the block.
  #4072 (permalink)
Old 06-18-2013, 07:01 PM
1971BB427's Avatar
I put the Falcon back together today. New balancer, water pump, and fixed the pulley for now. I was able to weld up a die to put on my 12 ton press and press out the couple dents in it. It spins true, but cosmetically still needs to be replaced when I can find one cheap.
BOBCRMAN-Your advice on balancer dimensions was great! I took the old one, and my dial calipers along, and checked it all before I laid down my money. Salesman thought I was sorta anal, but I could care less. It saved me doing it again, and it went right on! Thanks!
  #4073 (permalink)
Old 06-18-2013, 07:40 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Weeded my garden ,mowed 2 acres with a push mower , baby sat my grand kids, put a switch on the blue lights I installed in my Vettes side louvers that come on with the lights so if I get pulled over I can shut them off, installed a kill switch on the Vettes ignition, and pulled it out and washed it for the first time this year!
Jester
http://www.hotrodders.com/forum/atta...37160214702147
ID:	75002   Click image for larger version
ID:	75003   Click image for larger version
ID:	75004   Click image for larger version
ID:	75005   Click image for larger version
  #4074 (permalink)
Old 06-18-2013, 08:04 PM
Built Not Bought
That might have been my problem also,i had to take a brake cyl hone to the inside of mine it would go on about half way then stop would not pull on up even with a balancer installer..it is a Fluid Damper I bought from Ebay ,probably why they sold it, fits the old saying You Get what you pay for.
  #4075 (permalink)
Old 06-18-2013, 09:47 PM
Not much for me, but I did put a half hour or so in tonight before I ran over to my daughters school to help decorate for her big graduation from elementary school tomorrow. Oh yeah, and by the way, she is a straight A student!
So on the truck I sand blasted and cleaned up on the door, still have a little bit more before I can prime it and then weld it back together.
  #4076 (permalink)
1971BB427's Avatar
I buy a lot of my parts on Ebay, but sometimes I get stuck with junk, or things I have to rework to use.
  #4077 (permalink)
Old 06-18-2013, 11:14 PM
355 vortec heads
put a 355 together with vortec heads noisy gear drive and .450/.450 lift cam ran great on the stand.
  #4078 (permalink)
Old 06-18-2013, 11:20 PM
life is a temporary assignment
Didn't do alot today but did install my push rods and bolted down my tunnel ram, Also installed my harmonic balancer and oil and filter On my C-Cab..
  #4079 (permalink)
Old 06-19-2013, 12:02 AM
put up or shut up
finally the van side arrived at the shop. I handled cutting out the side on the van and the other guys tag teamed the chunk of steel by cutting out spot welds. One problem...Fords use weld bond/panel adhesive around the wheels on their vans and bed sides. So yeah, that's gonna be fun cutting that outer wheel house out(donor) and having to separate it without messing up the skin. Thank god the wheel house on the van needs to be pulled so it looks like I'll be tied up. I'll bring in my mini torch and have them cut around the wheel house(donor) and then heat up that wheel house lip while trying to separate it.
Also to follow up on something I said earlier. I mentioned loosening up the body bolts in the rear to release tension and let the body relax to square up the hole/rear door opening. It worked a little bit but I sped up the process with a huge sledge hammer and 4x4. Rather than gauging the results by looking at the door I did that but put more importance on looking at the mark where the mount used to be and how much I got back. It became unbunched. and the gap to the door got better.
anywho, the Cougar left today and the owner will be installing the head lights/taillights/ rear bumper/ door handles and then it gets new interior and subframed. So it will definitely come back in a month or so for a complimentary rub and I'll get pics of the interior. Got some pics of it today partially assembled and detailed. I'll upload those in a few days. Car turned out well for not being show quality. The team is clicking right now.
  #4080 (permalink)
Old 06-19-2013, 05:12 AM
jokerZ71's Avatar
Wrench Turner
No.I didn't ck @ teardown cuz my plans were to change crank.Since it'll now be a 350 or 355 build with the same crank,I reinstalled original crank to ck befor I hav block decked.
build thread, projects
« Hot Rod Gift?? | - »
Currently Active Users Viewing This Thread: 14 (2 members and 12 guests)
ntfday, tech69
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
