The "What Did You Work On Today" thread - Page 273 - Hot Rod Forum : Hotrodders Bulletin Board
  #4081 (permalink)
Old 06-19-2013, 06:46 AM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by tech69 View Post
finally the van side arrived at the shop. I handled cutting out the side on the van and the other guys tag teamed the chunk of steel by cutting out spot welds. One problem...Fords use weld bond/panel adhesive around the wheels on their vans and bed sides. So yeah, that's gonna be fun cutting that outer wheel house out(donor) and having to separate it without messing up the skin. Thank god the wheel house on the van needs to be pulled so it looks like I'll be tied up. I'll bring in my mini torch and have them cut around the wheel house(donor) and then heat up that wheel house lip while trying to separate it.
Also to follow up on something I said earlier. I mentioned loosening up the body bolts in the rear to release tension and let the body relax to square up the hole/rear door opening. It worked a little bit but I sped up the process with a huge sledge hammer and 4x4. Rather than gauging the results by looking at the door I did that but put more importance on looking at the mark where the mount used to be and how much I got back. It became unbunched. and the gap to the door got better.
anywho, the Cougar left today and the owner will be installing the head lights/taillights/ rear bumper/ door handles and then it gets new interior and subframed. So it will definitely come back in a month or so for a complimentary rub and I'll get pics of the interior. Got some pics of it today partially assembled and detailed. I'll upload those in a few days. Car turned out well for not being show quality. The team is clicking right now.
sometimes you can heat it up with a propane torch and the two pieces peel right apart but heat up the inner structure not the outer skin..might help to get it apart...
  #4082 (permalink)
Old 06-19-2013, 08:29 AM
I never get to post in here cuz it'd be boring LOL 4 days of 'built 4 speed' a week :-D
Ive gotta get some pics of my familys cabin. Its on 200 acres in the Adirondack's. Im also doing a refit on the cabin of my Dad's sailboat. God I havent even pulled the TA out of the barn this year.
  #4083 (permalink)
Old 06-19-2013, 08:52 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by 1971BB427 View Post
I put the Falcon back together today. New balancer, water pump, and fixed the pulley for now. I was able to weld up a die to put on my 12 ton press and press out the couple dents in it. It spins true, but cosmetically still needs to be replaced when I can find one cheap.
BOBCRMAN-Your advice on balancer dimensions was great! I took the old one, and my dial calipers along, and checked it all before I laid down my money. Salesman thought I was sorta anal, but I could care less. It saved me doing it again, and it went right on! Thanks!
I talked tp ASA today the pulley is $35 shipped if you want it,
  #4084 (permalink)
Old 06-19-2013, 08:59 AM
1971BB427's Avatar
Absolutely! Do you have contact info for ASA that you could post or PM to me? Thanks a lot David!
  #4085 (permalink)
Old 06-19-2013, 09:26 AM
put up or shut up
yeah, that was my plan. The sucky part is that stuff wraps around the lip and bend. No fun.
  #4086 (permalink)
Old 06-19-2013, 09:35 AM
We have an "Inductor" at work, DAMN does that thing work sweet for stuff like that. The INDUCTOR Induction Heating Tools for Automotive Professionals
You can remove a window with it, damn neat tool.
  #4087 (permalink)
Old 06-19-2013, 06:33 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
The shop were I work part time has one with coiled ends for heating seized nuts. No torch or heated surroundings, just the nut gets red hot. Neatest damn thing I've ever used for stuck nuts. Wish I could afford one...
I replaced the headliner and right door panel on the '52..
When I took the panel off, the sponge spacers were behind the panel, like I normally see. The other side had one on the outside, so I put them both out there. Now I know that is wrong and have to remove the left panel again to fix it.
I couldn't stand the butt-ugly grass green seat upholstery either so I picked up a $28 seat cover today. Keeps the Gray theme going...
  #4088 (permalink)
Old 06-19-2013, 06:41 PM
Built Not Bought
Is the foam pad factory or has it ben added,neither of my trucks have them so I probably need to find them.
  #4089 (permalink)
Old 06-19-2013, 06:45 PM
I've been fixing up the ditch mower too and today replaced more of the cutting hammers. I had 6 in stock and put them on last Monday and got more today.
You can see the sharp edge of the 2 I replaced a couple days ago and the worn out ones next to them.
That pile of parts is $600... I have 7 left for stock again now. If the mower hits a large rock that the frost pushed out of the ground, it will shing off a hammer and sometimes shear off the lugs welded to the drum.
All ready to work again.
The red handled broom is for reference. The handle is 5 feet tall...yeah I know, I own a vehicle with a four letter name....
Then I had to jockey cars around to get the '38 ready for Back To the 50's. I emptied the toy box and took a family photo...
  #4090 (permalink)
Old 06-19-2013, 06:58 PM
1971BB427's Avatar
Went for a short ride for gas today, as the expected rains didn't hit until a few minutes ago. All went extremely well. The car started a bit hard at the station, so I backed off the timing a few degrees when I got home, and now it hits right off hot or cold.
Was going to wash the dust off, but rains hit, so back in the canopy. But I did get some pics before I put it to bed! Had a neighbor follow me home from the gas station. He saw it going down the street, but didn't know I was building the Falcon, so wanted to see who owned it. Kinda funny when I pulled up and got out, he said, "I should have known it was going to your house!"
Here's the pics:
Wish the pass. side looked as good as the driver's side. I might not paint for years if it did!
  #4091 (permalink)
Old 06-19-2013, 07:31 PM
Worked on one of my tractors today, (day ain't done yet). A little while ago I had to go to my mail box to get the mail . I left the sprinklers on all last night and the driveway got a little wet. I might have had them on a little too high. The wife took a video of my trip up our drive. Take a look.
BB .
  #4092 (permalink)
Old 06-19-2013, 08:19 PM
Built Not Bought
You should have had your neighbor to take a picture of you standing next to your Falcon (fastest bird on planet) with that big smile on your face ,I bet it was there. Good Job.
  #4093 (permalink)
Old 06-19-2013, 08:22 PM
1971BB427's Avatar
Thanks David!
I never think of those things! He actually took pics of the car with his cell phone, but I stepped out of the way.
Previous owner is a neighbor, and he came over to see his old car also. He was very excited to see the jeckyl-hyde change to his car. Kinda surprised me that he'd like it so much!
  #4094 (permalink)
Old 06-19-2013, 08:34 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Installed the water pump and power steering and then had to fine tune the spacers for the alternator and compressor on the lathe. Also had to cut a slot in the reinforcing bracket I made.
The belt seems to be running true and a straight edge from the crank pulley for reference backs it up.
On to the AC system tomorrow.....
Name:	IMG_1288 (Medium).jpg
ID:	75022   Click image for larger version
Name:	IMG_1287 (Medium).jpg
  #4095 (permalink)
Old 06-19-2013, 08:39 PM
1971BB427's Avatar
Wow! That belt must be 8'-9' long!
build thread, projects
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
