The "What Did You Work On Today" thread - Page 291 - Hot Rod Forum : Hotrodders Bulletin Board
  #4351 (permalink)
Old 07-10-2013, 10:21 PM
I have so many of those projects around the house to do! I just have to put them off or nothing out in the garage will get done! But they are waiting there........oh yeah, they are waiting........
  #4352 (permalink)
Old 07-11-2013, 03:33 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Back to drawing house plans. Boring. It should get interesting if I ever get a permit and get started though...
  #4353 (permalink)
Old 07-11-2013, 08:42 AM
Originally Posted by 496CHEVY3100 View Post
I didn't bet to work on my truck last couple of days ,I have been doing Honey Do list building cabinents over the washer and dryer ,I built them with 3/4 in cabinet grade plywood on 2x2 franes I have the 2 coats of stain and just put on last coat of eurathane 3 coats, will build doors next week then sand and buff I have to get a new hinges and matching knobs and a roughter blade ,sounds like a good excuse to me. LOL
I haven't gotten to do anything with mine for a few days either. I will get back to it soon.
John
  #4354 (permalink)
Old 07-11-2013, 09:17 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Yea I have been missing your post,
  #4355 (permalink)
Old 07-11-2013, 05:54 PM
1971BB427's Avatar
I try not to miss a day, and follow Brian's lead of doing at least a few minutes every day!
Pulled the backseat and rear side panels today. Made my templates for covering, as old panels were warped and fugly.
Got the naugahyde marked out, and contact cement applied to panel and vinyl.
Slapped it together and installed them back on the car. Lots easier than the door panels, other than removing the seat bottom.
Just carpet left to do now, and the interior will be pretty close to done.
  #4356 (permalink)
Old 07-11-2013, 07:43 PM
Semper Gumby
Wiki Edits: 2
Picked up the "new" brake shoes for my foklift. New linings bonded on, wheel cyls rebuilt.
An hour drive to get them (on the other side of the city) and two and a half hours back, thanx to a wreck on a bridge
Cleaned out my parts washer, took the old "stuff" to recyclers, refilled it with 5 gallons of fresh solvent, then put it to use on forklift parts.
Cleaned and Re-packed wheel bearings, reinstalled wheel cylinders, gravity bled the system. As soon as I can find the sketch of which parts go where, I'll reassemble the brakes, put the axles back in and get it mobile.
Still gotta finish flushing etc the cooling system. Should have that done tonight.
THEN I gotta pick up the 6 Volt alternator I ordered to replace a "dead" generator, and fab up a mounting bracket for it.
  #4357 (permalink)
Old 07-11-2013, 11:15 PM
Tonight I came home to my 53-57 Corvette park lamps that came in the mail, WHOO HOOO. I am going to try to get as many real vintage Corvette parts as I can for the truck. I will never have a vintage Vette so this is as close as I will get damn it, I am going to at least FEEL like I am surrounded by a Corvette when I drive it.
I got on the truck thinking I would spend my five minutes and at least get a piece of metal cut out for the door. Well first off this takes an amazingly long period of time. It blows me away how long this tedious stuff takes. I spent about 40 minutes making this little piece of metal fit perfect, trimming the edge of the door a little and then making a template for the upper piece.
So what I did when I sectioned the door was to cut along the edge of the fold on the skin, removing the piece that overlapped the inner structure. Sectioned the inner structure and then tacked the skin back to the structure. Well the bottom of the door jamb isn't as wide at the bottom as it is a few inches up, so I had to narrow the skin by cutting some off as it rolls around the bottom of the door. I then rolled the lip up and will weld this piece that lip so it will essentially be exactly as it was before.
  #4358 (permalink)
Old 07-11-2013, 11:31 PM
Built Not Bought
Brian you are a craftsman,it takes a little longer to do it the right way ,But the end results will be worth it,
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
MARTINSR (07-11-2013)
  #4359 (permalink)
Old 07-12-2013, 12:00 AM
put up or shut up
today I worked on a Trans Am and got to see the Cab I worked on all finished.
These are both just drivers and the boss always says on these to not go crazy but I always tell him the bodywork always has to be the same, it's what happens after that changes. So the cab got one round of primer and soft padded with a DA. I don't agree with that unless you first block with a 240-320 then re guide coat and sand with the soft block but I'm not falling in love, it's a race truck. Still looks good. For a low end job I'm looking forward to seeing the Trans Am painted. I think it's gonna look pretty cool.
I got a bunch of new pics I'll load up tomorrow of different stuff I've been working on. Might also have some pics to show from an up and coming issue of a big time mag, so I hear. Hope it makes it in. Also will put up some new videos soon. I got tons of new footage.
  #4360 (permalink)
Old 07-12-2013, 12:08 PM
Built Not Bought
Did you lead that seam or did you weld and grind it smooth,
  #4361 (permalink)
Old 07-12-2013, 07:28 PM
1971BB427's Avatar
Noticed my steering felt a little "loose" whenever I was under power, or did a lane change. So I checked my toe in to see what it was. I had set it when I rebuilt the straight axle, but hard to get good measurements from backing plate to backing plate.
I found the frontend actually had toe out, instead of toe in! I loosened the tierod and put about 1/8" of toe in into it, and test drove it. Amazing the difference it made. It was OK before, but now it's great!
  #4362 (permalink)
Old 07-12-2013, 09:18 PM
Built Not Bought
I don't know much about straight axles,i have only owned one a 54 chevy and it was under it when I bought the car ,I yhink he said it was an econoline,to long ago,
I have been working on my Harley today ,had to remove saddle bags crash bars and rear floorboards to be able to remove rear tire, I am having to replace rear caliper again,i replaced it and rotor two years ago but I haven't ridden it in over a year so I guess it stuck and wont release so it will roll,will try rebuild kit first as it is only 40 dollars and a caliper is over 400 dollars.
Name:	Heritage Screaming Eagle 001.jpg
  #4363 (permalink)
Old 07-13-2013, 09:20 AM
1971BB427's Avatar
I don't know much about straight axles,i have only owned one a 54 chevy and it was under it when I bought the car ,I think he said it was an econoline,to long ago,
Yes, it's an Econoline straight axle.
I had that problem with my '76 Goldwing Ltd. David, only the front caliper. When it sat for long periods the front caliper would hang up. I pulled it apart and cleaned everything, then polished the bores and put in a new kit. It stopped the sticking.
  #4364 (permalink)
Old 07-13-2013, 05:01 PM
Last journal entry: Long time no journal entry, pulled hood tonight.
Got a new welder and drill press. Well new to me. Got the drill press set up. But will work on redoing my welding cart to fit the new welder later. The welder is a Hobart Handler 140. The drill press is a huge old delta unit with multiple speeds so i can work metal with it.
  #4365 (permalink)
Old 07-13-2013, 05:16 PM
I have had my Hobart Handler for at least 15 years Poet. It has been a great machine. Congratulations.
John
build thread, projects
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
