The "What Did You Work On Today" thread - Page 304 - Hot Rod Forum : Hotrodders Bulletin Board
  #4546 (permalink)
Old 07-27-2013, 05:38 PM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by 123pugsy View Post
Spent half the day changing the turn signal switch. What a pain!
I feel ya,Puggs... I just replaced the actuator on a tilt colume on an 89Buick Reatta very hard to find parts for since there were only 12,000 made the only other interchangable part is from a riviara, also hard to find. This car must love being at my shop because every time I fix something and get ready to deliver it something else breaks...
  #4547 (permalink)
Old 07-27-2013, 05:48 PM
Be careful where you cut. I doodled a bit showing what would happen near a curved spot compared to a a flatter spot.
Check it out:
Good point pugsy.
  #4548 (permalink)
Old 07-27-2013, 08:23 PM
1971BB427's Avatar
Spent the day at a very nice little cruise in out on by the local NAPA store. All free, along with food and entertainment. Plus they were giving out 5 gallon NAPA buckets full of cleaning supplies for your car! Never had such nice gifts handed out without having to buy raffle tickets to try and win them! They even gave away a 50" flat screen TV for free!
  #4549 (permalink)
Old 07-27-2013, 10:03 PM
put up or shut up
went to cosco and loaded up and it was after playing ball so I was sore. I'm thinking when I drink cranberry juice my joints start to hurt more after I play. In any case got some glucosamine and will take some apple cider vinegar more often, it helps a lot. Now I'm just kicking back reading up on some Vette stuff. Fiberglass isn't so bad as long as you have your storm trooper suit on. Watching more gasser glass videos and the guy is always mad...probably cause he works on only fiberglass. I'd be mad too. Awesome tips the guy has though. I think his videos have compelled me to start fabbing up a center console by using a bunch of molds.
  #4550 (permalink)
Old 07-27-2013, 10:31 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Spent a half hour out there tonight. I swear I have spent more time measuring out this one cut than I did on marking and cutting the roof off on the original cab I chopped in '74.
Brian, what is the advantage of cutting it the way you have marked? I have never done a chop personally so I have no experience with what you are doing. Thanks for the edumacation
Kelly
  #4551 (permalink)
Old 07-28-2013, 12:05 AM
put up or shut up
looks like a z notch for strength, but a pain to fill in with strips. Not sure though. Care to explain, Martin?
  #4552 (permalink)
Old 07-28-2013, 12:29 AM
Kelly
What I have done is cut over the door at the point where lengthening that area must be done, then moved it back to the rear of the cab where lengthening the skin works without going across the middle of the roof where you have to deal with a larger flatter area that is much harder to weld without distortion.
Just as when it was sectioned, the door jamb area needed to be cut at the widest point so the two pieces come back together matching. But I Z cut it down to the bottom of the cab so I didn't have to weld right thru the middle of the back panel where welding could be much more difficult.
I brought the cut down literally to the bottom of the cab right at a factory seam.
Welding all across the back with literally no distortion at all. Can you imaging welding all the way across the center of that panel!
Or the cowl, where the cut was made at the widest point in the jamb where with the piece removed the two halves come back together meeting perfectly. Then I Z cut it up to above the fender. Then moved it higher still to cut it across the top of the firewall where I simply trimmed off the sectioned amount from the top of the cowl overhang instead of cutting thru the middle of the firewall which would create all kinds of work.
The Following User Says Thank You to MARTINSR For This Useful Post:
tech69 (07-28-2013)
  #4553 (permalink)
Old 07-28-2013, 12:37 AM
Sooooo today I got up went out to the garage with a few minutes I had before heading out of town to bring my wife and daughter to my oldest daughters baby shower. While there the guys went out and did as opposite girly thing as we could, we went to the shooting range and made loud noises.
But I started out by looking to mark the extra piece of the B pillar to use to extend the roof jamb.
I was going to use the extra roof to lengthen the cab by cutting it longer and simply using the front off of the other roof, but it is so darn rusty and I am tired of the rust.
So I have decided to simply lengthen the top and get it over with. And that was that until I am out on the road for two hours driving to my daughters and it hits me, I can cut this piece from the extra roof so I don't need to fab one up! The piece from the B pillar really needs a bunch of work to get it to fit, I might as well fab one from scratch. So using a piece from the donor roof will make this a lot easier.
  #4554 (permalink)
Old 07-28-2013, 12:40 AM
Check it out:
Yes, it's a good thing to think about. The cut I will make isn't on much of a curve at all and the skin will simply go where I want. It isn't like it won't move like dropping the roof it's self with slanted windshield posts, it will move where it needs to go. It's only a little bit of a change in height where I am cutting it and the lengthening is only going to be about an inch and a half.
  #4555 (permalink)
Old 07-28-2013, 02:43 AM
Last journal entry: Long time no journal entry, pulled hood tonight.
I worked on the exhaust on my 68 caddy. Did some practice welds on the old exhaust pieces till I got it right. That was what went right. The welding a patch panel in under the car to fix the Y pipe didn't go so well. Just couldn't do it right, so now my next goal on the caddy is to get the Y pipe off. Which I am making progress. Got one 45 year old nut off the passenger side, the side with better access. Could not do a thing with a half inch breaker bar on the others, so I did a little hacking with the dremel. Still don't have all the nuts off, one on the driver's side is going to wait till I get a new air hose and a 9/16 impact socket. And hopefully the mac 3/8 impact will be able to break it loose because it would be simpler. The 1/2 inch would require a bit more work to get it on the nut. Basically turn it upside down and maneuver it around the power steering box. After all that I can drop the Y pipe and then do what work needs to be done, or possibly go dual exhaust and scrap most of the Y pipe.
  #4556 (permalink)
Old 07-28-2013, 04:01 AM
Banned
Felt good enough to try to work on engine other than the cramps and having to run(and I mean run) to the bathroom 10 times in 2 hours, I got some stuff done, vacuumed out all the metal shavings from drilling the pushrod holes bigger, timing cover cleaned off and installed oil pan on after resetting oil pump pick up.
button bolts on back of water pump to clear the composite timing cover.
then got out compressor to fill cyl with air to change out the valve springs for ls9 beehive springs, ever try to compress valve springs with those cheap pry bar type, head on engine spring compressors,
[img]http://www.lulusoso.com/upload/20120...r_VT01288_.jpg[/img]
well, they suck, will be buying the type the screws down
[img]http://www.tooltopia.com/_img/KDT/KDT3271.jpg[/img]
as the pry bar type pushes the spring off center and makes it a ROYAL pain to get the locks in and out.. got 2 done, and called it a day.. as the cramps where getting worse.. and I looked like I just jumped in a pool I was sweating so much.
  #4557 (permalink)
Old 07-28-2013, 05:51 AM
Wiki Edits: 11
I played around with some ospho and a new rust remover ....
I still cant figure out why your having so much trouble ,Brian
I did this in a couple minutes,two different days (drying time)
ID:	76065   Click image for larger version
ID:	76066   Click image for larger version
ID:	76067   Click image for larger version
ID:	76068   Click image for larger version
  #4558 (permalink)
Old 07-28-2013, 08:02 AM
I can't either Mke!
  #4559 (permalink)
Old 07-28-2013, 09:14 AM
put up or shut up
today I will be cleaning out the garage and if I'm not feeling too lazy I will reorganize some of the parts for my Mustang. We loosely got a time frame in which I can have it trailered to the shop to finish it off and this works well with me cause I really like to get stuff done working odd hours into the night but the the obstacle is do I want to do that in my own house with a baby inside? Not a chance. I work my arse off everyday for that place in blistering heat and the last thing I want to do is bring that home with me and do the same thing on the weekend. If it's in the shop it's a different story though. So I'm looking forward to getting this done, just not at my house.
  #4560 (permalink)
Old 07-28-2013, 06:49 PM
My daughter, son in law and grand kids came for the weekend. We will be keeping the girls this week before they go back to school.
Tim and I played in the basement for a while. He has not had much time with a MIG welder so I cut up some pieces of 18, 20, and even some 12 gauge scrap for him to practice on. He really made a lot of progress and by the time we kocked of he was doing some really nice tacks and but welded a couple of pieces of 18ga pieces together. The next time he makes a brace he will get to weld it together himself.
While he was welding I was making a template for the cowl mount and started making a replacement piece but not much to look at yet.
Hopefully I will get a little done while the girls are here. Time will tell. Glad to have them anyway.
John
build thread, projects
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
496CHEVY3100, 123pugsy
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
