The "What Did You Work On Today" thread - Page 308 - Hot Rod Forum : Hotrodders Bulletin Board
  #4606 (permalink)
Old 07-30-2013, 07:12 PM
1971BB427's Avatar
Thanks again! At least he's got an option to dropping the tank if he wants to save time and labor! If it was my car I'd sure go for this method. Especially since I've gone through this on a '95, and it was not fun! I found out later about cutting a hole on the 4th gens, and that hurt even more!
  #4607 (permalink)
Old 07-30-2013, 07:17 PM
Project89's Avatar
ive owned 13 of these cars , and most of them ive had to replace the fuel pump either to it dieing or needing a bigger pump.i now prefer the acess door
my current car has 3 pumps in the tank( one on all the time 1 for when boost goes over 12 psi and the 3rd comes on when the nitrous is activated) , i can swap out the pumps in about 25 mins if i need to ,ive done it once already on the side of the highway.
makes life so much easier , and with the quality of the replacement pumps chances are u will prolly be going back into the tank again at some point
  #4608 (permalink)
Old 07-30-2013, 07:26 PM
1971BB427's Avatar
Well I wont be back in there! Once I help him discover the process you described, then it's his baby, and he'll do it himself next time!
  #4609 (permalink)
Old 07-30-2013, 07:55 PM
ProStreetRob's Avatar
5.7L S10 LS SS
I worked on relaxing, it's car show season
  #4610 (permalink)
Old 07-30-2013, 09:38 PM
Project89's Avatar
this sound like its missing on 1-2 cyls to any of u guys ?? ( disregard the squeeling belt im waiting on new alt brackets since my top bracket flexes and makes it squeal )
guys on my local forums swear up down its only running on 6/7 cyls , even though i know its running on all 8
and yes this is what i worked on today
  #4611 (permalink)
Old 07-30-2013, 09:57 PM
Semper Gumby
Wiki Edits: 2
A non-contact "laser" thermometer (even the el-cheap-o from Horrible Fright) will tell the tale. Just take the temps of the individual exhaust headers
  #4612 (permalink)
Old 07-30-2013, 09:59 PM
Project89's Avatar
i already did that i know its not missing , was just curious as to if it sounds like it, to me it sounds just like it should being it has twin turbos , and the downpipes are only 3.5 ft long , with no mufflers
  #4613 (permalink)
Old 07-30-2013, 10:21 PM
Man are you guys over my head with that stuff!
Tonight I did some rust clean up, testing some products. Man am I sick that I left this cab outside, darn it!
  #4614 (permalink)
Old 07-30-2013, 10:37 PM
Last journal entry: Update
I spent most of the day at a Pick a part getting a tranny for a VW Golf and looking around at a bunch of cars & trucks that all but made me sick. Anyone know what the little blue van is? I'm thinking Renault but ...
Name:	2013-07-30 10.52.14.jpg
ID:	76210   Click image for larger version
Name:	2013-07-30 10.53.10.jpg
ID:	76211   Click image for larger version
Name:	2013-07-30 10.53.02.jpg
  #4615 (permalink)
Old 07-30-2013, 10:51 PM
A few more pics. Can't get the pics to upload !!!!!
Name:	2013-07-30 10.52.56.jpg
  #4616 (permalink)
Old 07-30-2013, 11:06 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
check out the suiside doors.
  #4617 (permalink)
Old 07-30-2013, 11:18 PM
Semper Gumby
Wiki Edits: 2
The little blue van does indeed appear to be Renault (good eye!)
A 1960 Renault Estafette Fourgon in fact
  #4618 (permalink)
Old 07-30-2013, 11:58 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
Fan Belt and fuel pump
I spent most of the day replacing a fan belt. The P/S pump came loose and the belt came off while I was on my way to the shop. The LT-1 has a Street and Performance pulley setup, so I called them to get a part number for the belt and what they gave me was wrong. trial and error resulted in a correct belt but the parts store was almost a mile away and I had to walk there -- twice. The fancy tension adjuster was corroded, so I had to disassemble and clean it to make it work. I had to disconnect a lot of stuff to replace the belt; it all goes back together tomorrow after lunch.
The rest of the day, I spent tracking down a correct re-build kit for a Carter fuel pump for a 54 Desoto Firedome that uses the rare caged valves. That should be here by the end of the week.
  #4619 (permalink)
Old 07-31-2013, 12:21 AM
Actually the drivers door slides back into the body, not a suicide door in truth. I wasn't sure about it being a Renault as all the badging was removed as well as the grill, horn button and interior. Pretty much all there is left is the body.
  #4620 (permalink)
Old 07-31-2013, 05:21 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
RUST CONVERTER !!!! spray it on, let it dry and forget about that rust.
And quit whining about rust...when your whole floor falls out, THEN you have rust...
The Following 2 Users Say Thank You to Too Many Projects For This Useful Post:
BruceKoukalaka (07-31-2013), John long (07-31-2013)
build thread, projects
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
