The "What Did You Work On Today" thread - Page 309 - Hot Rod Forum : Hotrodders Bulletin Board
  #4621 (permalink)
Old 07-31-2013, 06:21 AM
ProStreetRob's Avatar
5.7L S10 LS SS
Originally Posted by Project89 View Post
this sound like its missing on 1-2 cyls to any of u guys ?? ( disregard the squeeling belt im waiting on new alt brackets since my top bracket flexes and makes it squeal )
guys on my local forums swear up down its only running on 6/7 cyls , even though i know its running on all 8
and yes this is what i worked on today
Definitely doesn't sound right and it sure does seem like it's missing (as if it's not running on all cylinders)
The Following User Says Thank You to ProStreetRob For This Useful Post:
NEW INTERIORS (07-31-2013)
  #4622 (permalink)
Old 07-31-2013, 09:13 AM
I'm assuming you've checked the "Crash Relay " to see if it needs to be reset. It should be up under the dash on the pass side on the firewall.I remember having a similar problem with a Ford and that was the answer. When it's activated it's function is to cut off power to the fuel pump.
BB
  #4623 (permalink)
Old 07-31-2013, 09:24 AM
BB
Wow, I knew they existed but probably would never have thought about reseting it. I wonder how many good fuel pumps have been replaced? Do they make them for after market installations like street rods or could you take one out of a wreck and wire your pump through.
  #4624 (permalink)
Old 07-31-2013, 09:42 AM
Originally Posted by Too Many Projects View Post
RUST CONVERTER !!!! spray it on, let it dry and forget about that rust.
And quit whining about rust...when your whole floor falls out, THEN you have rust...
LOLOLOLOL, waaaaa, waaaaaaa, I am still crying.
  #4625 (permalink)
Old 07-31-2013, 09:48 AM
put up or shut up
today I'm just glad to be out of the shop. It's like trying to do things the right way is a sin around here. Time to go on vacation and have some fun!
  #4626 (permalink)
Old 07-31-2013, 10:00 AM
If Brian is crying about rust, I am hysterical.......
  #4627 (permalink)
Old 07-31-2013, 10:32 AM
John, I have so much respect for you guys who rebuild a super rusty car. I have done a LOT of rust repair over the years, but it was all pretty localized. Window channels for instance, my shop was across the street from a glass shop so I did too many sixties and seventies GM cars to count. I sure as heck did stuff more severe but don't remember them (must have blocked the memory out ).
But this every square inch rust crap, haven't dealt with it since my brothers Roadster, we simply had it sand blasted inside and out as it needed work on every square inch. But damn in a garage with the limits we have, it's tough.
  #4628 (permalink)
Old 07-31-2013, 10:42 AM
Last journal entry: Update
Just grab one from a wreck and install yourself, make sure you get the pig-tail as well as it will help in keeping the wiring attached
  #4629 (permalink)
Old 07-31-2013, 01:16 PM
Project89's Avatar
its running on all 8 maybe its just the way my iphone records sound on its videos, its got brand new plugs in it acdelco r42's and they all look good just a touch rich but none of them are fuel soaked or clean
  #4630 (permalink)
Old 07-31-2013, 09:32 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
The fuel pump on my '66 Chevelle is wired thru the oil pressure switch. If the engine quits from a frontal crash, roll over or brake/wheel lock up ( I have a 4 speed), the pump quits too. It is a common 3 pole switch but I can't remember the NAPA number right now. I actually have a T at the block for this as I also have a mechanical oil pressure gauge under the dash.
The Following User Says Thank You to Too Many Projects For This Useful Post:
John long (07-31-2013)
  #4631 (permalink)
Old 07-31-2013, 10:01 PM
Been working on the '38 for weeks now. Many surprises and set backs along the way but it is starting to shape up.
Went from this..manual rack, single quad tunnel ram.
To power rack, coil over conversion, Vintage Air/heat, Performer RPM and TH350 to 200r4 trans.
  #4632 (permalink)
Old 07-31-2013, 10:30 PM
Last journal entry: Long time no journal entry, pulled hood tonight.
Bought a bunch of stuff, air hose, air tool accessory pack, 3 wrenches and a handful of sockets, new welding gloves, new safety glasses, and a hone for the wheel cylinders.
I used the hone already to clean up the wheel cylinders. Put it in my new drill press, which illustrated I need a vise there, even if just a cheap one. But I made it work. Held the wheel cylinder with one of my new welding gloves.
Also tried some to loosen the exhaust bolts on the caddy. Not much luck with the 3/8 MAC impact, but I didn't try the 1/2 inch CH wrench or even find my PB blaster. So I really didn't try to hard. Will leave it for the weekend.
  #4633 (permalink)
Old 07-31-2013, 10:51 PM
You are going to be riding in style AND cozy.
  #4634 (permalink)
Old 07-31-2013, 10:54 PM
The impact on stuff like that works wonders. Turn it down low and let it hit hit hit hit hit that hitting will break stuff loose if anything is. I will even go in and out turning it in and out. If it goes just a hair out you may not know it. While if you go in and out it will screw back in that hair, then on the way out it has a better chance of moving two hairs. Then over and over and over and next thing you know it's unscrewing all the way.
The Following User Says Thank You to MARTINSR For This Useful Post:
silentpoet (08-02-2013)
  #4635 (permalink)
Old 08-01-2013, 01:27 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Good advise Brian ,that works good for me also ,I also replace the nut that comes off with a Brass nut ,I get them at NAPA they hold good and will come off easy the next time they need to be removed ,,don't over tighten .
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
build thread, projects
Currently Active Users Viewing This Thread: 12 (1 members and 11 guests)
mud.man.rj
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
