The "What Did You Work On Today" thread - Page 338 - Hot Rod Forum : Hotrodders Bulletin Board
  #5056 (permalink)
Old 09-04-2013, 08:17 PM
Last journal entry: Long time no journal entry, pulled hood tonight.
On second thought, it is apparently only 3.29 at Orielly's. Gonna just replace it.
  #5057 (permalink)
Old 09-04-2013, 08:31 PM
Originally Posted by 496CHEVY3100 View Post
this is what it was like.
I may be mistaken about this, maybe it's just a lot newer or something? That kick stand is Schwinn, hmmmmmm
  #5058 (permalink)
Old 09-04-2013, 08:33 PM
HOLD ON HERE! That's a different frame!
The one in the earlier pictures doesn't have a Schwinn kickstand in it! Did someone do a switcho chango with your frame at some point?
  #5059 (permalink)
Old 09-04-2013, 09:13 PM
Here's a site that you might be interested in.
BB
vintage schwinn bicycle | Got Free Shipping? United States
  #5060 (permalink)
Old 09-04-2013, 09:24 PM
As long as Schwinns came up_________
BB
  #5061 (permalink)
Old 09-04-2013, 10:19 PM
1971BB427's Avatar
Hit the Wed. night cruise at Beaches tonight. A beautiful 75 degree evening, and only a few hundred cars showed up, vs. the 1200-1500 that usually show on a nice night. It's been slow all summer for some reason.
  #5062 (permalink)
Old 09-04-2013, 11:50 PM
put up or shut up
cut out a support on an Isuzu Trooper and pulled the apron. We just ordered a 90 degree side clamp so we don't have them yet so I had to leave a small portion of the support on the apron and still bolted into the front cross member. Then used a plate and bolt to pull in that area. This allowed it to stay straight where it needed to stay straight and un crumple where it needed to uncrumple. I'm kind of glad we didn't have the side clamp cause I probably wouldn't have tried it that way and it worked out great. The upper rail has swayed a tad and is in still though so tomorrow that will get worked out and brought back to spec...after someone converts them to inches for us on the computer.
The Chrysler 300 is getting assembled by the owner and going next door for interior. So I hope he gets the side chrome on before he pulls it out of here so I can snap more pics. I snapped some today and will put them up by Friday, in hopes I get more with the side chrome. Certain colors look good with chrome and that's one of them.
  #5063 (permalink)
Old 09-05-2013, 03:14 AM
Pats55's Avatar
One nifty little tool
Today I finally got to spray the bottom of the 55. It took about two weeks to strip the undercoating, the grease and rust from the bottom. I sprayed the silver primer on today with an engine cleaning gun from Taiwan. I purchased it at Harbor freight for seven dollars. I have used these for years. This sprayer will blow paint about 18 inches. It's great for all the hard to reach areas, and for spraying inside rockers and anywhere else that access is difficult.
  #5064 (permalink)
Old 09-05-2013, 05:38 AM
ProStreetRob's Avatar
5.7L S10 LS SS
I also hit a Wed night cruise / gathering and although around here has also been a little slow this season the quality of vehicles has been great and anytime I drive the beast I have a smile from ear to ear
Got to admit my truck was looking dam good last night
ID:	79161   Click image for larger version
ID:	79169   Click image for larger version
ID:	79177   Click image for larger version
  #5065 (permalink)
Old 09-05-2013, 05:35 PM
Last journal entry: Continuing BodModOp... Body Modifiation Operator
As a sidebar note on bicycles; The frame on my 1962 Triumph Bonneville was brazed together. It was my first bike that I bought new and wish I could remember what I paid for it... not much in today's dollars.
We used to make Weed Burner Pipes for our fuel car and gas welded them to the flanges with steel filler rod. After a few passes we'd have to re-weld them if we were fortunate enough not to have driven over an ejected pipe or two.
Then we learned to braze the pipes to the flanges and life was better. Then Zoomies took center stage which reduced the stresses on the flanges and we had more time to drink coffee between passes.
  #5066 (permalink)
Old 09-05-2013, 07:11 PM
Bought the part, did the required cursing, and got the last shoes on. It is all over except for the bleeding. Probably Saturday.
  #5067 (permalink)
Old 09-05-2013, 07:15 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Did the same thing with the power steering pump on my '69 Suburban. It sits down low under the alternator, so I need to use a funnel with a long tube to get it in. I put a new hose on the other day and while filling it I got it overfull before I knew it and it ran all over the chassis and ground. Then I had to suck some out to get it below the full mark too!
Well thanks for trying to make me feel better. It is good to know you aren't alone.
John
Faaaaaaaar from alone on that one. I've alsways disliked the PS pump under the alternator on GM's. I overfilled my '38 pump TWICE after I installed it. The second time was after I had to drain it to fix a leak... You'd think I would've learned the first time...
  #5068 (permalink)
Old 09-05-2013, 07:18 PM
Since you took care to adhere to this step, it should all go good now...
  #5069 (permalink)
Old 09-05-2013, 07:27 PM
Semper Gumby
Wiki Edits: 2
Did you also make the requisite blood sacrifice to the automotive gods? Unless you bark or scrape a knuckle and leave some of your skin & blood in the car, it will NEVER run again!
  #5070 (permalink)
Old 09-05-2013, 07:30 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Hmmmm. Maybe that's why my hands are so scarred up. Many a blood sacrifice over the years. I have made other mechanics wince when I explain where some of the scars came from.
build thread, projects
« Come On Man! | - »
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
boothboy
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
