The "What Did You Work On Today" thread - Page 36 - Hot Rod Forum : Hotrodders Bulletin Board
  #526 (permalink)
Old 03-02-2012, 06:27 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by 1971BB427
Built a little cover for the top of my new master cylinder bracket to clean it up. Still need to polish it up a bit.
I tend to go a little overboard, even on little things like that. I grind the welds smooth and finish with surface conditioning discs before painting. Even a little body filler applied with a finger tip to pits in the weld and sanded, if needed. Just me.
  #527 (permalink)
Old 03-02-2012, 11:11 PM
bruce mckenzie's Avatar
Last journal entry: getting close now
Originally Posted by Irelands child
Bruce, Thanks.
The entire chassis is a TCI Stage 3, my retirement 'present' to myself.
Dave W
Ha thought so did you find enough caster adjustment on the top bush, I recon there is just enough and no more, also did you get the discs to wondering what type of car they came from
  #528 (permalink)
Old 03-03-2012, 05:56 AM
Irelands child's Avatar
Bruce - I'm currently at between 4 and 5 degrees caster with 31" tall tires in the rear, 25" in the front creating somewhat of a chassis angle "rake". There is possibly another 1-2 degrees left. The front rotors are American Granada, 1975-80 with a the standard Ford 4-1/2" wheel spacing
Irelands child
  #529 (permalink)
Old 03-03-2012, 02:36 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
1) A MK4 VW jetta: did a cv shaft swap. Turns out the CV shaft nut didnt tighten down properly when i torqued it. By the time i had it parked in the street I could hear the wheel bearing dieing a quick death.
By the time i had the car back up to the shop, it was totaly done for. I had to torque the thing down beyond belief to get it to pull back together enough to send the customer on his way overnight.
Monday I will be swapping out his month old wheel bearing for a new one. Luckily its and hour job and the bearing is lifetime warranty.
2) 2000 Audi S4: has a pesky low oil pressure light. Spent 3 hours screwing with it while the customer that JUST bought the car waited in the office. Swapped the sensor, motor flushed it. dropped the pan and inspected the oil pump. pulled the sensor and screwed in a pressure gauge to see what the actual pressure was ...
Turs out the pressure is ABOVE SPEC and the problem is that the car has an aftermarket tune thats got a glitch.
Monday we will be swapping the ECU w/ a brand "X" tune for the one we have laying around with a brand "Z" tune
  #530 (permalink)
Old 03-03-2012, 06:20 PM
Well I got out to the garage and sand blasted and epoxy primed my battery tray brackets. Painted another color on my instrument cluster, pretty close to being done with that. I then went thru all the bezels and knobs I have to find the best ones that I will detail. I found that my work horse gun wasn't working up to par and I pulled it apart to find that it was FILTHY. I don't pay a whole lot of attention to it being it isn't for base coat or clear or anything like that, I use it for shooting chassis stuff, something that isn't too critical. I also loan it out for people doing primer and just not to worried. Well, it was full of crap! LOL, guess I should think about it a little more. So I cleaned it up for the black tomorrow on the battery tray.
Didn't get a whole lot done but this still took me five hours!
  #531 (permalink)
Old 03-03-2012, 07:00 PM
Wiki Edits: 49
Managed to get everything in the garage and shop packed in a 24' truck for the move to Texas. All my tools, and two big block Mopar engines in pieces and one assembled including a half ton of extra parts along with a TH-350 trans I need to rebuild one of these days.
Won't be working on cars for a while.... at lesast till I get my new garage and house built.
Centerline
HotRodsAndHemis.com
"If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
  #532 (permalink)
Old 03-03-2012, 07:22 PM
Centerline
HotRodsAndHemis.com
WoW, now that's a big deal! Drive safe!
  #533 (permalink)
Old 03-04-2012, 06:22 PM
Accomplished a lot on the 70 LeMans.
Got all rear lights working.
Rear bumper is ready for installation.
Removed both rear side windows, regulators and weather strip.
Started inside door clean up & inspection.
Tried starting the 400 cid but forgot I had a low battery.
BT
  #534 (permalink)
Old 03-04-2012, 07:07 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
My Lawn Tractor
Transmission went out----ordered new one.
Today started the task of removing the trans
damn jack stand bit my finger before i even got started.
Had son take me to the hospital
Six stitches to hold the tip of my finger on---hope it stays there
  #535 (permalink)
Old 03-04-2012, 07:40 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
Centerline
HotRodsAndHemis.com
X2^^^^^^good luck, be careful
Originally Posted by Bryan59EC
My Lawn Tractor
yikes I hope you are OK
I also was working on the outdoor equipment, my wife has 2 big rototillers both are broken, each for different reasons, so I tore them both apart
now I'm going to take all the best parts, order a couple of new parts, and make one really good tiller, and one not so good tiller
ID:	63710   Click image for larger version
ID:	63711   Click image for larger version
ID:	63712   Click image for larger version
  #536 (permalink)
Old 03-04-2012, 07:53 PM
Last journal entry: Finally some floor!
Didn't really have too much energy today to get much done. Got back around 12:30 am from flying to Richmond, VA. and picking up my wife's replacement car. She's got about 230,000 on her 98 Cavalier so it was about time. Found a nice 2005 Buick LaSabre with an honest 12,500 Miles! I was kinda apprehensive but it is a really nice car. I know you are all going to laugh at this, but it was REALLY owned by a little old lady who drove it to church, store, and to get her hair done. Fell and broke her hip and now she can't drive! Been off her feet for a while I guess. She gave her hair dresser Power of Attorney and that's who sold her car for her. (Honest guys I'm not makin' this up!). Anyway, I flew there from Indianapolis yesterday morning and left there about 3:00pm. Put it in the wind and used the cruise as much as possible and it took me right at nine hours. I sure hope that it lasts her a long time because those flying low trips aren't nearly as much fun as they used to be! Only problem will be the garage door (I already hung the tennis ball from the ceiling so she can have something to aim for when she pulls it in!)
Not really been getting a lot done on the project lately. Putzin' with brake lines, fuel, etc. Couldn't decide what to do with the firewall. I plan on an aluminum faceplate but I wanted the firewall behind it to be decent also. The stock one has a lot of unused mount holes, etc. Have finally decided to replace the biggest part of it. Pulled the master cylinder and all lines I have made from the master and get ready to cut it out.
  #537 (permalink)
Old 03-04-2012, 09:38 PM
My Lawn Tractor
Oh damn Bryan that sucks!
  #538 (permalink)
Old 03-04-2012, 09:43 PM
I got a lot done today, first off I said goodbye to the SHO, no more Fords for me. For a number of years there that is all that was in the driveway were a couple of Fords, now I'm a Mopar Dude with the Caravan and the Rambler (well Chrysler did end up buying them).
I did a bunch of parts cleaning and painting on the dash, painted and installed the battery tray brackets and tray. Went up into my "stock" and found a bunch of stuff I forgot I had. I have everything I need for the convertible, window rubbers and top rubbers and tack strips and everything! WHOO HOO.
I got the visors in, I really got a lot done, double WHOO HOO!
  #539 (permalink)
Old 03-05-2012, 07:20 AM
Last journal entry: My Last Hot Rod
No parts
I cut a tree up that I flopped last fall. Going to need that fire wood for the next winter
  #540 (permalink)
Old 03-05-2012, 08:31 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Well,
I bought a new Moroso kick-out Pan (#20411) for my build (everything else is going to the Machine Shop week of 3/12), and thought I should put it on and see how it fits before I take it-the darn thing is 1/2" too wide for my Headers and the drain plug points directly at one of the Collectors-
So, this morning I found one from B & B (Stef's) and ordered it-no kick out, but it has a Trap Door and Baffle/Crank Scraper-
I then cut-out the front piece for my Console out of 18 gauge CRS, put it in the Bead Roller, beaded it and then used my tipping dies and bent the flange-because it is such a drastic contour (5" at the bottom flaring to 14" at the top in 20" or so) I had to get out the Lancaster stretcher so that the Flange would bend over-then I made an angle bracket, stretched it as well to match the contour of the bottom of my Dash-mounted it w/button heads, then punched three holes in the Console piece and plug welded it to the Flange, mounted it-when I got ready to Mig Weld it, I realized that I forgot to turn off the Gas last week and it was empty- , so I broke out the Tig (I can use the practice anyhow)-
Next, I am making some Panels to go toward the Firewall, and I will punch/dimple die some holes in that so that the Heater can vent to the Floor-prodding ever so slowly ahead, but at least it's progress!
build thread, projects
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
luvbuildingcars
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
