The "What Did You Work On Today" thread - Page 38 - Hot Rod Forum : Hotrodders Bulletin Board
  #556 (permalink)
Old 03-07-2012, 03:21 PM
Bad Rat's Avatar
Last journal entry: SACRAMENTO AUTORAMA 02/05
Wiki Edits: 2
Originally Posted by Bad Rat
I spent most of the day cleaning the shop, moved a couple of cars around to make some room for a little repair project coming in on Wed ,on a 41 Ford P/u that Speedy Bill Smith ( of Speedway Motors fame, )built and drove,,
A friend bought it at auction, I'll post some pictures as soon a s it gets here
well it was longer than I expected,, but we have been having crappy rainy weather, but today turned out to be decent so he brought it over today,, couple of pictures,, really nice P/U
ID:	63795   Click image for larger version
ID:	63796   Click image for larger version
ID:	63797   Click image for larger version
ID:	63798   Click image for larger version
  #557 (permalink)
Old 03-07-2012, 03:44 PM
Irelands child's Avatar
Originally Posted by chevy3600
Has anyone drilled out the pan and inserted a plug, even one with a magnet to draw out the filings?
Here are several - I've used the B&M as well as the Summit house brand
These both work just fine, but may seep a wee bit
  #558 (permalink)
Old 03-07-2012, 04:08 PM
I have always loved those trucks and that one is fine example.
What are you going to do with it?
  #559 (permalink)
Old 03-07-2012, 06:57 PM
Bad Rat's Avatar
Wiki Edits: 2
#1 It needs a hood safety latch, # 2 figure out the security system, I think it is a sequence button type system, ( a button has to be pushed a specific number of time to acctuvate ) or several other things in sequence, my idea is to completely eliminate the system,, and start over,, that could be a real head scratcher,,
# 3 adjust the drivers side front fender, for the hood to fender gap, # 4 tune up, oil and tranny fluid change, mostly just little things that need attention,,,
  #560 (permalink)
Old 03-07-2012, 07:38 PM
1971BB427's Avatar
I contemplated welding a bung on the pan to make a drain, but when I saw what they wanted for a decent chrome pan with a plug I changed my mind. I paid $15 at last year's swap meet for a new one still wrapped in plastic.
There's not much clearance inside a TH350 pan between the valve body/filter, and the pan, so it might be tough to weld anything inside. I'd cut a 3/8 pipe plug in half and braze one half of it to the side of the pan down low. Then drill a hole through it to drain, and install a brass plug. Most TH350 pans have a magnet inside from the factory, so no need for a magnetic plug.
  #561 (permalink)
Old 03-07-2012, 07:40 PM
1971BB427's Avatar
Great looking PU Bill! Getting her ready for spring cruising?
  #562 (permalink)
Old 03-07-2012, 08:08 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Finger still sore.
But lawnmower moved under it's own power this afternoon.
Tomorrow----I put the deck on and maybe cut some grass.
(put a bigger, badder transmission in my mower----this thing hauls now.
Hills no longer an issue)
  #563 (permalink)
Old 03-07-2012, 08:18 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Problem was, I did mine back in 1990. Didn't know about internet then, much less Summit racing. Got the drain plug and a nut from Big A Auto parts. That was in Wyoming. Is Big A even still around ?
  #564 (permalink)
Old 03-07-2012, 08:51 PM
Heck in 1990 you still had to call 1-800 and talk to a REAL person at Summit ... but that's about the time I did one on my ancient F350's C6 transmission.
No car work today - but did make a stop for our RV to prevent the top of of the kitchen slide out from moving while traveling over rough roads. I also discovered that I can make a mess on two work benches, a table saw, a radial arm saw and a drill press while cutting, milling and drilling 4 small pieces of 2x4 .
  #565 (permalink)
Old 03-07-2012, 09:14 PM
Well I started out tonight with a very cool step, bolting in my instrument cluster assembly. It ended up being a bit frustrating as I can't figure out how to plug some things in. Sounds easy, but damn something isn't making sense. Will hit the assembly manual tonight.
  #566 (permalink)
Old 03-07-2012, 10:03 PM
Prof. T. Soggmeyer's Avatar
Plan B
Big A left my little town in the early nineties.
  #567 (permalink)
Old 03-07-2012, 10:08 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
The last one I saw was in Saratoga, Wyoming, and I left there in 1994.
  #568 (permalink)
Old 03-08-2012, 01:01 AM
bruce mckenzie's Avatar
Last journal entry: the boy
made some hinges last night
Need a way of hinging the hood on the Willys as there is no allowance for it in the fiber glass body i have this is how I have gone about it, there is still a bit to do but I am sure you will understand what I am doing
ID:	63822   Click image for larger version
ID:	63823   Click image for larger version
ID:	63824   Click image for larger version
ID:	63825   Click image for larger version
  #569 (permalink)
Old 03-08-2012, 03:56 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Excellent idea and execution.
Gives me something to think about with my build.
  #570 (permalink)
Old 03-08-2012, 06:22 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
i bought some rototiller parts, more on order
build thread, projects
