The "What Did You Work On Today" thread - Page 467 - Hot Rod Forum : Hotrodders Bulletin Board
  #6991 (permalink)
Old 02-02-2014, 04:53 PM
put up or shut up
Originally Posted by dsraven View Post
for my bead roller I went to the hardware store and picked up some shim washers that fit the shaft where the dies go on. that way you can get different shapes from the same dies. like the step dies will give a less crisp edge over a wider area if that is what you are after. just pick up some scrap at the scrap dealer or use an old fridge door to practice on. I also made up a new die from a grade 8 washer and ahub for a weld on sprocket. welded the washer on where the sprocket should go, then spun the whole thing in the drill press and took the edge off the washer with a file to get a contour for a tipping die. use a skate board wheel under it or the flat part of the step die. just goof around till you get what you want.
have fun and check the clock every once in awhile, otherwise you come in the house and everybody else has gone to bed long time before.
haha
dennis
the stepping dies are awesome and have already planned on getting washers! I have a weird issue with the shafts though. Is this normal? The bolt doesn't even hold the bottom die on there. Seems like a defect but not sure.
ID:	118393   Click image for larger version
  #6992 (permalink)
Old 02-02-2014, 05:01 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Looks like you need a good assortment of spacers.
  #6993 (permalink)
Old 02-02-2014, 05:51 PM
put up or shut up
on the shafts where the stepped areas are(where the dies rest) it seems like they have to be even in order for the gaps to be even on the female bead dies to the male dies. So I think I got that part right but the shaft ends seem too long. Are they supposed to be the same length as the upper?
  #6994 (permalink)
Old 02-02-2014, 06:02 PM
CraigK's Avatar
Last journal entry: For a change of pace
Bad luck weekend was right. I got my hinges re drilled for the new pins and stopped work today. Everything I looked at went sour. Lost my door remote for the garage, made 3 trips for wiper blades after one blew off the coly. The third trip i just changed it in the parking lot. I should have done that the first trip. My primer inside my doors flashed off 16 hours late in the middle of the night.
ID:	118409   Click image for larger version
  #6995 (permalink)
Old 02-02-2014, 07:14 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Is there any adjustment in them at the rear? Maybe the bottom can slide back somehow?
If so, then you would add more spacers behind the die.
If not, say the heck with it, and add some spacers in front of the die so you can tighten the bolt.
  #6996 (permalink)
Old 02-02-2014, 07:25 PM
Like dsraven, I bought some 1/16 in shims from my local Ace Hardware. They were 45 cents a piece and can be placed in front or behind the dies to get exactly the spacing you need. EZ fix and opens up other possibilities for the profiles you can make.
My shafts are 22 mm but 7/8 shims work perfectly.
John
  #6997 (permalink)
Old 02-02-2014, 07:34 PM
if you bought an el cheapo deluxe roller like i did you will need to go through all the set screws on the gears etc to make sure they are all tight. that is when i set the spacing on my roller so the shafts line up on the inboard end. if the shafts are a little too long the add some spacers but at least the inboard part is the same so the dies are centred on themselves. do yourself a favour and add the little spring to help lift the shafts up when you relieve the pressure, it just makes life easier if you are doing it all by yourself like me. i used a spring from the hardware store, a valve spring retainer from a motorcycle on the top then adjust it as required for tension.
  #6998 (permalink)
Old 02-02-2014, 07:44 PM
put up or shut up
thanks guys! I think I will push the bottom shaft back so the washers are on the inner part of the shaft and so I don't have to worry about taking them on and off every time I switch dies. Man, it's a lot of fun playing with this thing.
  #6999 (permalink)
Old 02-02-2014, 07:48 PM
Also take a few minutes and drill the bearing blocks and install some zerk fittings. They will become gaulded in no time if you don't.
John
  #7000 (permalink)
Old 02-02-2014, 07:55 PM
put up or shut up
John
I got the Woodward fab one because it has them already. Thanks for the washer sizes. Will head out there tonight to get some.
  #7001 (permalink)
Old 02-02-2014, 09:51 PM
Careful, The sizes I gave were for the HF. May be different for the Woodward Fab model.
John
  #7002 (permalink)
Old 02-03-2014, 04:13 AM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by americanLT1 View Post
Well, yesterday I thought I might luck out on my dash and only have to repair the black areas and re-clear but further inspection today showed a crack that of course is in the orange. So, looks like a complete redo is in order.
I set the dash in the car anyway to see what should have been this weekend
I also installed the carpet.
Ed
still, it looks fantastic
  #7003 (permalink)
Old 02-03-2014, 08:24 AM
hey, tech69, i just thought of something. check the shaft on the roller to make sure it didn't get installed backwards. maybe if you swap it end for end the machined area will be the same length as the other one and will match up. I think mine had more area machined on the end where the gears are. is yours a powered model or hand crank? crank is good for control but it sure is nice to have power if you work alone. it is hard to control the sheet and crank the handle at the same time. that is why i powered mine with a drill.
  #7004 (permalink)
Old 02-03-2014, 08:37 AM
put up or shut up
yeah, I quickly realized that about the powered ones. Going slow seems to be the key but a powered one would be awesome. Care to post some pics? I'd love to find an alternative to those $200 motors everyone is putting into them.
  #7005 (permalink)
Old 02-03-2014, 10:34 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
John Long installed a garage door motor on the cheap.
build thread, projects
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
adantessr
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
