The "What Did You Work On Today" thread - Page 468 - Hot Rod Forum : Hotrodders Bulletin Board
  #7006 (permalink)
Old 02-03-2014, 11:58 AM
Originally Posted by 123pugsy View Post
John Long installed a garage door motor on the cheap.
Here is a link to my thread where I powered mine up. Several other guys had some really good posts about how they did theirs too.
John
Converting bead roller to power
The Following 2 Users Say Thank You to John long For This Useful Post:
123pugsy (02-03-2014), NEW INTERIORS (02-03-2014)
  #7007 (permalink)
Old 02-03-2014, 02:13 PM
Semper Gumby
Wiki Edits: 2
AC-DC power for a bike
Originally Posted by americanLT1 View Post
I'll be, AC current.
The AC current for a bike actually makes sense. In a car, things evolved from battery powered ignitions in the days of Model T's, and later, when generators were the standard approach, the generators put out DC power.
When car manufacturers switched to alternators, they had to make them compatible with existing (all DC) systems. So diodes and rectifiers were built into the alternator to yield DC power. Early alternators still used the generator's old external voltage regulator systems.
If, however, you are starting with a "'clean sheet of paper" in design, then you have an alternator (putting out - by definition) AC power, and since things like bulbs work just as well on AC as on DC, so...
On many bikes, the alternator is part of the flywheel and a rectifier actually just cuts off the "other side of" an alternator's AC output (sending it to ground) - effectively cutting the total output in half.
So if you use ALL of the alternator output for lights and only run the stuff that really NEEDS to be DC through a rectifier, you can cut down the size of the alternator, eliminate most of the rectifier load (and reduce the size of the - now external- rectifier, too) and reduce costs in manufacturing, and simplify engineering.
Now if only they had actually made that feature clear in manuals etc. ...
Result: Headlights, taillights etc are MUCH brighter on AC (they get twice the power). Only turn signals (which need a DC flasher to function) need to go through a rectified system. Much less overall power is needed to run everything.
Wonder how much simplification could have occurred in cars if such an approach had been followed!
Maybe I should put this into the "electrical" section of this site....(?)
  #7008 (permalink)
Old 02-03-2014, 06:03 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Worked on my interior some today installed carpet and made some sill plates not bolted down yet ,should have removed the safety tape before photo ,,I am very slow at this as it is my first interior other than just bolting in replacement pieces,
second photo was 1st attempt.
Name:	53 CHEVY SEATS 002.jpg
ID:	118785   Click image for larger version
  #7009 (permalink)
Old 02-03-2014, 06:14 PM
deadbodyman's Avatar
Wiki Edits: 11
Is there any adjustment in them at the rear? Maybe the bottom can slide back somehow?
If so, then you would add more spacers behind the die.
If not, say the heck with it, and add some spacers in front of the die so you can tighten the bolt.
There should be some set screws in the gears That'll allow you to slide the shafts back and forth ,same set screws in the roller dies ,the bolt at the end of the shaft keep the roller from falling off the set screws hold it in place...
  #7010 (permalink)
Old 02-03-2014, 06:22 PM
That's looking great. Are you going to run full door panels or leave the bottoms exposed like stock? I like that look personally. My truck will have full panels though. I didn't want to ad the work needed to make it all correct while sectioning the door. But I dig it showing the painted panels like original.
  #7011 (permalink)
14 hour day driving big truck. came home worked on my little girls 1959 VW bug.
  #7012 (permalink)
Old 02-03-2014, 06:26 PM
mud.man.rj's Avatar
smooth is right..
x2 on the smooth, same for the super clean garage, could eat off that floor, mine would kill you..
  #7013 (permalink)
Old 02-03-2014, 06:28 PM
CraigK's Avatar
Last journal entry: For a change of pace
I am curious, that chrome beading in your window rubber has my attention. I screwed up and ordered chrome seals, yet I have no chrome. *sigh* Is that chrome beading factory? Can I buy it and add it to mine? Is it on the windshield also? I am not sure what to do a set of window seals for chrome beading. I was going to return them and get right ones, but the cost of freight is as much as the seals. That chrome beading looks nice. I could do some if I knew where to order it from. Hint hint. ( Please don't sat LMC, I have bad with freight being in Canada )
  #7014 (permalink)
Old 02-03-2014, 06:31 PM
CraigK's Avatar
I agree, nice doors need to shown off. Mine will be open on the bottom for sure. Same with my floor. That floor of mine didn't come easy and I am not covering it up.
  #7015 (permalink)
Old 02-03-2014, 06:35 PM
Built Not Bought
As of now I am planning on running full door panels that I am making from 1/8 pvc board also the kick panels and headliner (insert ) will all be made from same material and covered with Infinity ly camel leather.
Thanks for the kind words.
  #7016 (permalink)
Old 02-03-2014, 06:46 PM
Built Not Bought
The chrome IS factory for a deluxe cab I also tried lmc .brothers amd Jim Carter,neither fit the way I wanted it to,my front windshield is stainless also side windows the (wind guard on vent windows and drip moldind not installed yet ) is all stainless and inside window trim I have is stainless but I think I will buy some more and paint it to match the leather..my rear windows are a rubber / plastic rope seal ,I bought the ones that FIT @ Georgia Classic Parts thet specialize in 55-57 Chevy Parts they recently started stocking parts for 48-54 chevy pu I don't have web adresse but phone # is770-921-3244
they also sell new and vintage used parts. Lilburn Ga
  #7017 (permalink)
Old 02-03-2014, 06:56 PM
Built Not Bought
I forgot to post but the quarter rubber with chrome insert is only $20 and center is $ 17 with chrome insert.
  #7018 (permalink)
Old 02-03-2014, 07:15 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Welcome aboard Cameron.
  #7019 (permalink)
Old 02-03-2014, 07:42 PM
Built Not Bought
I also have a 59 my wifes Aunt and Uncle bought new amd donated it to me just before they passed away a couple years ago''I call it Hazel in memory
paint bad but runs great
  #7020 (permalink)
Old 02-03-2014, 07:44 PM
Nothing really exciting to report. I am glad to say I got to the garage for about an hour and started cleaning up the body. Getting it ready to install the rear floor pans I am making.
It is good to get back to work.
John
build thread, projects
Currently Active Users Viewing This Thread: 13 (2 members and 11 guests)
Rodnit, luvbuildingcars
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
