The "What Did You Work On Today" thread - Page 469 - Hot Rod Forum : Hotrodders Bulletin Board
  #7021 (permalink)
Old 02-03-2014, 06:49 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Nothing really exciting to report. I am glad to say I got to the garage for about an hour and started cleaning up the body. Getting it ready to install the rear floor pans I am making.
It is good to get back to work.
John
Any work is a step in the right direction ,,
I have noticed you have ben slackin lately I LOL
  #7022 (permalink)
Old 02-03-2014, 07:01 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
John
Yay, back to the rust.
  #7023 (permalink)
Old 02-03-2014, 07:04 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
I was out in the garage working on the new rotisserie project. If I can get it rolled over, it sure will be easier to work on it. I plan on using the rotisserie to move it to the chemical strippers as well.
  #7024 (permalink)
Old 02-03-2014, 07:18 PM
Have you thought of building a hoop style rotisserie Pugs? I have been thinking it may be more compact. I wonder about the pros and cons.
John
  #7025 (permalink)
Old 02-03-2014, 07:20 PM
Irelands child's Avatar
I've gotten the last possible piece off my SB Ford from the '31 and pulled the oil galley welch plugs, tapped the holes and fitted socket head NPT pipe plugs. I ordered everything I didn't already have for the engine (re) build up. The 331/347 stroker upgrade has been abandoned as not being cost effective (my too thin wallet) though some aluminum heads are still in consideration.
Dave W
Irelands child
  #7026 (permalink)
Old 02-03-2014, 07:38 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
John
Nope, wouldn't consider it.
I'm doing a copy of one I seen on a google search. It uses trailer axles and bearings for the spinner thing a ma jiggies.
Mine will come apart for easy storage.
Something like the pics attached.
ID:	118809   Click image for larger version
  #7027 (permalink)
Old 02-03-2014, 08:11 PM
here are a few pics of my modified el cheapo deluxe bead roller. it was a made in china model. it was economical so I can't complain but when I was practicing, trying to roll some 18ga for my old truck, I found that it flexed quite a bit with the heavier stock. I re-inforced it with 1/2" flat bar from the scrap yard. then realized that cranking was not going to work for me because I could't crank and hold the sheet at the same time. I removed the crank and got a hub that fit the shaft (it is used for weld on sprockets and I picked it up from an industrial supply vendor) then welded on a flex plate for a chevy 350. then gutted a starter i had kicking around from a chevy 3.1 malibu. I got a shop to turn down the end of the armature so it would stick out through the rear of the starter housing, then put it all back together and shimmed up the drive so it would be "engaged" all the time.then I made a bracket to mount the starter so it would engage with the flywheel. I hooked up my makita 1/2" variable speed drill and tried it out-worked ok. then made the bracket for the drill, the gas pedal style treadle connected with some bicycle cable and a pulley arrangement (to make the pedal travel further for the same travel on the trigger-more control that way) with a lever to operate the trigger on the drill. I used a pto cable stopper on the end of the cable for adjustment. works ok. you could fab it all up on the cheap in a few hours. mostly it is figuring out how everything will fit.
give it a try and if it doesn't work all you have to lose is a few bucks and a couple hours of your time.
have fun
Name:	bead roller and stretcher 006.jpg
ID:	118825   Click image for larger version
Name:	bead roller and stretcher 005.jpg
ID:	118833   Click image for larger version
Name:	bead roller and stretcher 007.jpg
The Following User Says Thank You to dsraven For This Useful Post:
tech69 (02-03-2014)
  #7028 (permalink)
Old 02-03-2014, 08:22 PM
Not only do I like dsraven's design, I like the way he did his lift spring on the upper shaft.
Good design. Also gives variable speed that I do not have though I find I can do a good job pulsing my motor through tight turns. Raven's design should be as economical as any I have seen.
John
  #7029 (permalink)
Old 02-03-2014, 08:48 PM
here are a few more pics with some better detail, in case you feel like motorizing on the cheap. it really doesan't take a 1/2' drill, you could probably use a 3/8 drill, because of the gear reduction in the starter nose.
Name:	bead roller 001.jpg
ID:	118849   Click image for larger version
Name:	bead roller 002.jpg
ID:	118857   Click image for larger version
Name:	bead roller 003.jpg
ID:	118865   Click image for larger version
Name:	bead roller 004.jpg
ID:	118873   Click image for larger version
Name:	bead roller 005.jpg
  #7030 (permalink)
Old 02-03-2014, 10:06 PM
Damn those tools are neat!
I did nothing but open the box that came in the mail with my new Bionic face shield. Man is this thing worth the few extra bucks, much better than any shield I have ever used. If you want a new shield get one of these, that's my recommendation.
I can't wait to get the tinted "visor" so I can go weld with my bi-focals on.
  #7031 (permalink)
Old 02-03-2014, 10:26 PM
put up or shut up
thanks for taking the time to show me these. Man, I might just look into getting a conversion kit. That's a lot of work. I want to skip all that and get to the fun stuff.
  #7032 (permalink)
Old 02-03-2014, 10:28 PM
put up or shut up
It looks nice but I'm not very careful with full face shields and I'll scratch em up quick. Wondering if they sell any with peel off protection type stickers. That would be cool. The one I have I can barely see thru it, but don't use it often anyways so I'll probably just go to HF to get another one some day. I recall you saying you can't wear goggles though so that sounds like bread and butter for you.
  #7033 (permalink)
Old 02-03-2014, 10:32 PM
I'm hoping Henry, I'm hoping. I think it will work great. The scratching, that is something I am thinking about. I am thinking I need to treat it like it's gold, if I take real good care of it that should make a big difference. They do make a "coated" lense but not in the #5 shade for some reason. We will see, the darn shade costs as much as the whole assy!
  #7034 (permalink)
Old 02-03-2014, 10:56 PM
Built Not Bought
have you thought about using ,Tear offs ,designed for motto X racind
they come in various tints and some are dark enough to use with a plasma cutter they should attach to your shield an as you get thim dirty or scratched just tear it if and throw it away.
Nice shaild this should save it,
  #7035 (permalink)
Old 02-03-2014, 11:18 PM
I have "tear offs" for my painting respirator hood, I can look into that.
build thread, projects
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
