The "What Did You Work On Today" thread - Page 505 - Hot Rod Forum : Hotrodders Bulletin Board
  #7561 (permalink)
Old 03-10-2014, 06:08 PM
1971BB427's Avatar
Engine shop called today, and my new engine is headed to the assembly bench! All the machine work and blueprinting is complete. Everything needed very little adjustment to correct bore centers, align bore, deck, balance, etc., so in a couple days I can pick it up, and drop the heads back on, and put it in!
Ordered my Crower cam saver lifters today, and the new cross ram intake should be here about the same time as the engine. I want to sand and polish the cast finish off the intake before installation, so that will hold me up a bit.
I'm excited to see what it all looks like when it's done!
The Following User Says Thank You to 1971BB427 For This Useful Post:
123pugsy (03-10-2014)
  #7562 (permalink)
Old 03-10-2014, 06:17 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
should look like this ,only better with polished intake
  #7563 (permalink)
Old 03-10-2014, 06:24 PM
Built Not Bought
Didn't get much done to my truck today,workrd a couple hours didn't change looks much.
my dogs kept getting in my way,
Moe ,Larry and Curley
ID:	127313   Click image for larger version
  #7564 (permalink)
Old 03-10-2014, 06:33 PM
Last journal entry: door trim
finally got to work on the head liner in my coupe. had to add some more wood to the existing wood cross supports that I put in when I replaced all the wood in the body. added enough to make all supports the same plane.
Then I used 1/4 luwan ply to make the base of the panels. split the panels down the middle and started to fit one half. after that i made another the same size and adjusted it to fit the curve a little better. 'After that i tacked the panels up to the bows and checked the fit and then marked the holes where the plastic push bolts will go. I have no idea what the correct name is for these things but their plastic with big heads 1/4" x 3/4". they uase them to hold plastic parts in cars.
I hot glue them to the plywood them sand all the edges so the fabric won't get caught on the wood edge. I used 1/4 upholstery foam first, glue both sides and roll it flat, then trim it, After that I fitted the matching fabric to my seats to make sure its about 2-3" bigger than the wood. then I spray glue both sides and Carefully apply the fabric and smooth out any wrinkles. then I roll it with a Formica roller and turn it over and do the same for the left over fabric. I then use a heat gun and warm up the service and roll it again to make it tight.
After that i lined up each panel with the holes in the wood and tapped it in. Once both panels were in I used a plastic mallet and block or soft wood and tapped the plastic bolts in tight. Next week I will install the dome light, in some of the pics you can see the wires hanging down, also my wiper motor is in the ceiling and you can see where the knob goes.
After the light is in I plan on finding a piece of chrome trim of some kind and run it down the seam from the rear window to the light. I'm putting my radio and little glove box above the windshield in some kind of frame which I need to figure out yet.
ID:	127329   Click image for larger version
ID:	127337   Click image for larger version
ID:	127345   Click image for larger version
ID:	127353   Click image for larger version
The Following 2 Users Say Thank You to sportcoupe For This Useful Post:
123pugsy (03-10-2014), John long (03-10-2014)
  #7565 (permalink)
Old 03-10-2014, 06:57 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Got a rocker clamped and screwed into place. I had to cut two braces and move the B pillar back and outwards.
  #7566 (permalink)
Old 03-10-2014, 07:15 PM
Better now than later. Keep the pictures coming. Like it
John
The Following User Says Thank You to John long For This Useful Post:
123pugsy (03-11-2014)
  #7567 (permalink)
Old 03-10-2014, 07:35 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Sweet. I don't believe that I have ever seen a chevy cross ram intake before. Saw one on a Dodge or Plymouth back in the 60's. I remember it looked like two octopus fighting.
  #7568 (permalink)
Old 03-10-2014, 09:16 PM
I literally spent 20 minutes in the shop tonight but did get a start on making the floor pan settle into place. It was hard to walk away just when i was getting started on it.
John
  #7569 (permalink)
Old 03-10-2014, 09:27 PM
put up or shut up
looking good you two.
Don't know how I made it thru the day but I did. Yesterday I couldn't put any weight on my ankle whatsoever. Not even walking on it holding onto countertops/walls/etc. It just wasn't up to the task so I hopped on one leg, with my daughter hopping on one leg right behind me-lol. Today I was able to limp on it so I went to work with my slippers cause my shoes is out of the question right now with this huge bubble on my foot. I sat on milk crates while sanding and buffing a door but had to stand as well. After a while my foot got so numb it didn't hurt as bad. Then I got home and wanted to show my wife I wasn't completely helpless so I then made dinner, ate dinner quickly with the family, then hurried over to a chair to elevate my ankle with some ice. I'll give it a hot-cold-hot-cold-hot-cold treatment later tonight in the bath and will be back tomorrow...in my slippers.
  #7570 (permalink)
Old 03-10-2014, 09:32 PM
Hopefully the boss appreciates the fact you were there Henry. I know sometimes that is not the case but hopefully it is this time. Hope it heals quickly.
John
  #7571 (permalink)
Old 03-10-2014, 09:33 PM
1971BB427's Avatar
Close David. Mine is a Weiand, so it's not an open plenum like the factory cross ram, and the carbs aren't staggered, they're straight across. Like this one:
  #7572 (permalink)
Old 03-10-2014, 09:39 PM
put up or shut up
John
funny you mention it. The plan was to go there, put the car together with the boss' lap dog, then sand n buff it. I got to work(boss wasn't there) and said I wasn't sure how long I could go for so I said I'd buff it while he's putting it together cause no one else there knows how to buff but they know how to put stuff together. I thought it was a great idea cause if I had to cut out at lunch than the car could have still gotten done. So the boss gets into an argument with his lap dog and his lap dog leaves saying he's quitting. An hour later the boss comes in and I tell him he left pretty upset and he said, "I know cause he doesn't listen, nobody listens around here". This was all over the fact that I buffed it earlier instead of buffing it later.
  #7573 (permalink)
Old 03-10-2014, 09:43 PM
1971BB427's Avatar
Originally Posted by tech69 View Post
funny you mention it. The plan was to go there, put the car together with the boss' lap dog, then sand n buff it. I got to work(boss wasn't there) and said I wasn't sure how long I could go for so I said I'd buff it while he's putting it together cause no one else there knows how to buff but they know how to put stuff together. I thought it was a great idea cause if I had to cut out at lunch than the car could have still gotten done. So the boss gets into an argument with his lap dog and his lap dog leaves, saying he's quitting. An hour later the boss comes in and I tell him he left pretty upset and he said, "I know cause he doesn't listen, nobody listens around here". This was all over the fact that I buffed it earlier instead of buffing it later.
Not sure how you put up with such a horse's rear!
  #7574 (permalink)
Old 03-10-2014, 09:45 PM
Built Not Bought
They will look great,thinking about converting my cross ram on my corvette to carbs if they ever give ant trouble ,,so far they have not..
  #7575 (permalink)
Old 03-10-2014, 09:47 PM
What the heck did I miss here Henry, what happened to you?
build thread, projects
Currently Active Users Viewing This Thread: 19 (3 members and 16 guests)
boothboy, Rodnit, sportcoupe
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
