The "What Did You Work On Today" thread - Page 651 - Hot Rod Forum : Hotrodders Bulletin Board
  #9751 (permalink)
Old 08-20-2014, 07:06 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Iknow very lttle about the stovebolts,,I didn't know the heads were interchangeable,i wouldn't mind having a 250 or 292 with early head and valve cover for my 50 chevy pu.
  #9752 (permalink)
Old 08-20-2014, 07:28 PM
KVP's Avatar
KVP KVP is offline
Oh HELL YES that's an awesome little car! DAMN what a great driver that could be!
Marge met Carmen today at work one of my co-workers cars he finally drove to work.
Brian, you need to check out the cars for sale on the H.A.M.B. and take a look at Marge's long lost sister. After seeing the asking price for her, you'll have a whole new appreciation of Marge. I agree with you on the Fairlane. I'd love to own one like it. What a fun driver it would be. Keith
  #9753 (permalink)
Old 08-20-2014, 07:39 PM
I am not sure if that can be done. 53 may have been a transition year. I just know they use a valve cover like a 48-52 even though they are full oil pressure. The straight shift in 53 was still a splash lube even though the Powerglide was full oil pressure.
Whether or not the 53 head will fit a later model block or not, I just don't know.
John
  #9754 (permalink)
Old 08-20-2014, 08:29 PM
Built Not Bought
The engine I have I think is a 49 so it would have babitted rods and no pressure feed ,it is a fresh build but I am not going to use it,\it came out of a car then was built.
  #9755 (permalink)
Old 08-20-2014, 08:42 PM
I really doubt you would be satisfied with it. If I know you, it needs to be able to run the highway at 65-70 without burning up. No matter how fresh, it is still obsolete technoligy.
John
  #9756 (permalink)
Old 08-20-2014, 08:59 PM
I don't claim to be an expert on the subject, but AFAIK, there is very little interchangeability between the early (216/235) and late (194/230/250/292) Chevy sixes
  #9757 (permalink)
Old 08-21-2014, 12:27 AM
Cars, Trucks, Boats
. Yes, late Chevy sixes have much more interchangeability with the SBC V8's... but might be able to fake an early valve cover onto a later engine for 'the look'...
. Always wondered, how do they get oil up into the top/rocker arms of the splash lube sixes?
. I knew Chevy's were always advanced OHV, no flatheads, but shocked to learn they didn't get an oil pump till part of '53...
  #9758 (permalink)
Old 08-21-2014, 12:43 AM
Cars, Trucks, Boats
Originally Posted by NEW INTERIORS View Post
MAN !!!!! What's going on with these people ???? They put your motor in backwards too !!!!! Mine is ***** backwards too...
. At least they grabbed a proper distributor...! ... Thinking about going GM HEI on my '78 Ford F150 351M/400... my '86 Monte Carlo usually started so quick never heard the starter crank it over hot or cold... but with this Ford Duraspark it always has to crank over several times before there is any sign of life to it... gotta be harder on the starter... plus, while it's cranking, I'm always wondering if it's going to come alive... often a minor problem somewhere in all the scattered ignition parts and/or connections...
The Following User Says Thank You to BuzzLOL For This Useful Post:
wretched ratchet (08-21-2014)
  #9759 (permalink)
Old 08-21-2014, 08:52 AM
1971BB427's Avatar
Got my wrinkle walls out and screwed the beads so they're ready to put on the Falcon for the pre '64 drags this Sunday at Toutle, Wa. We're heading up Sat. and will camp out at the track. Sunday is the event, and expect 100+ cars to attend and race. Fun event, and make as many passes as you can fit into a day!
Hopefully the Eagles will hook better than the Hurst pie crusts did last year! The Hurst are so hard the Falcon spun them the length of the 1/8th mile. Starting out at 20 psi, and I'll lower them down until they bite well. I've got some old skinny tires/wheels to hang on the rear for towing the car, so I don't have to tow it with the slicks on it.
  #9760 (permalink)
Old 08-21-2014, 12:23 PM
The rods had little scoops on the bottom that picked up oil; but I'm not sure how the top end was done, unless they relied on the cloud of oil that was floating around the engine
I do know that the later 235s were decidedly low-tech in that department: A simple metal tube dumped oil on top of the rocker shaft
  #9761 (permalink)
Old 08-21-2014, 12:52 PM
It appears that they did have an oil pump, but pre-1953 was a low pressure system that relied on splash to feed the rod bearings
1958 Rock Arm Assembly Lubrication
  #9762 (permalink)
Old 08-21-2014, 01:41 PM
wretched ratchet's Avatar
one full turn after it squeeks
All this 235 talk is sure making me miss my '56 Jimmy.
  #9763 (permalink)
Old 08-21-2014, 03:19 PM
Semper Gumby
Wiki Edits: 2
They had a pump - just not a high pressure or volume one. When I was but a kidlet, my dad drove a '49 Chev, and it had enough of a pump to be able to use a partial-flow (hung off the side) oil filter with replaceable cartridge in it.
Believe it or not, Chev did not incorporate an oil filter into design of the inline 6's until 1961!
  #9764 (permalink)
Old 08-21-2014, 03:25 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Waiting to go in my '52 flatbed...
The Following 3 Users Say Thank You to Too Many Projects For This Useful Post:
John long (08-21-2014), MARTINSR (08-22-2014), wretched ratchet (08-21-2014)
  #9765 (permalink)
Old 08-21-2014, 08:11 PM
My '59 Chevy had one hanging from U-bolts on the intake manifold
I don't remember if my '61 truck (which I believe also had a 235) had one or not
build thread, projects
« How cool is this | - »
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
John long, cgates
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
