What is the difference between a Dana 60 and a Dana 61 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2008, 07:03 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Anybody know the difference between a Dana 60 and a Dana 61. I was wondering because my old 67 F250 Camper Special has a Dana 60 and my 78 F250 Camper Special has a Dana 61. They look identical except my 78 F250 has a rear sway bar.
Old 09-20-2008, 07:22 PM
SSedan64's Avatar
I looks like a standard Dana 60 but has a different offset for the carrier and therefore will require modifications to run certain ratios. Seems like it is made for higher numerical ratios than the 60 if IIRC.
