What are the differences between a 3/4 and 1 ton Chevy?
I have a 1978 Chevy C20. It sits about 4 inches taller than My 1974 C20 and it rides a lot rougher. It sits so tall that some people have mistaken it for a 4X4. It can haul a big load of wood without very much sag at all. I know it has been wrecked and rebuilt at some point in time. I am wondering if someone put the cab on a one ton frame. What are the differences between a 3/4 and 1 ton Chevy?
Yes it has been "tagged" |
Crash,
I do believe that those 78's were available with a factory heavy duty spring option and you got one..Your other one probably has the regular duty springs on it..Just my guess but if you can find the build sheet which may be under the seat I think you can learn some more.. Sam
My Comparison is from what I have
1985 Chevy Silverado 20 3/4 ton Suburban & a 1988 Silverado 30 Dualie. some of the things I noticed that were heavier on the dualie are as follows ~The frame after the front suspension gets wider the 3/4 is 6 " & the dualie is 8" wide but both seem to be about .025" thick ~The Dualie has heavier bolts everything seems to be grade 8 ~The dualie stuff... tie rods ,sway bars ,springs & brakes are substantially bigger as well as the master cylinder is too. ~The 3/4 ton has a 14 bolt Full floater rear & 13" drums while the dualie has a Dana 70 with 13" drums but the shoes are much wider {i don't remember the measurements} But one thing I noticed was that the Burb has 245 -70/R 16 load range "E" & the Dualie has 235 - 85/R 16 load range "E" they seem to sit at the same hight in the front. Well that is all I can think of for now . Does that help some? R
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
