What differential will replace a 1954 Chevy Pickup? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2012, 10:43 PM
I want to use a 3.36 to a 3.5 gear ratio in my 1954 Chevy pickup. The stock 54 pickup rear end has a 55 inch backing plate to backing plate dimension. What later model rear end will fit in the truck and be in the right gear ratio?
Old 02-22-2012, 07:40 AM
RWENUTS's Avatar
Check this out. Rear gear swaps and more.
http://www.patricksantiquecars.com/chevy_parts.html
Old 02-22-2012, 08:56 AM
1954 Chevy Pickup rear end question
I should have eloborated. I will using a 700R4 Transmission and need to get rid of the enclosed driveshaft. Any help as to what other Chevy rear end will fit the 55 inch backing plate to backing plate dimension. Thanks for your help.
Old 02-22-2012, 09:36 AM
RWENUTS's Avatar
Are you staying 6 bolt rims?
Old 02-22-2012, 02:11 PM
I have swapped in 73-87 10 bolt 6 lug rear axles two times.It's about 2 inches wider than stock but barely noticeable.A better choice is the 60's 12 bolt truck axle as it's almost the exact same width.The actual widths do vary so measure before buying.You have to install new spring perches and cut off some unused brackets.
The mounting flange to mounting flange width of the stock AD rear axle is 62 inches,backing plate distances are not really that important in this situation.
Old 02-22-2012, 03:47 PM
reply to RWENUTS and TRUCKEDUP
Currently, the truck is all original with an enclosed drive shaft with a 390 gear ratio and 6 bolt lugs.
I would like to remove the original rear end and put a 5 or 6 bolt lug nut pattern with a 355 to 342 modern gear ratio and have an open drive shaft so I can hook up a 700 R4 transmission.
Someone told me the best gear ratio would be a 342. Positraction is optional.
Old 02-22-2012, 04:39 PM
RWENUTS's Avatar
Here's link for rearend widths. You might need to blow up the chart a bit to see it. The best way to measure is from wheel mounting surface to surface.
http://www.myspace.com/bomberscarclub/blog/481908067
Old 02-22-2012, 05:13 PM
Wiki Edits: 49
Mid '70s Camaro or Firebird works perfectly.
Centerline
HotRodsAndHemis.com
"When buying a used car, punch the buttons on the radio. If all the stations are rock and roll, there's a good chance the transmission is shot." - Larry Lujack
1954 Chevy 1/2 ton pickup brake lights latebloomer Electrical 4 06-12-2010 09:49 AM
1954 pickup with Chevy HEI, no Spark Truckingrodder Electrical 5 06-11-2010 09:48 AM
Help Start a 1954 Chevy Pickup low50s Electrical 3 02-08-2009 08:28 PM
1954 chevy pickup horton2828 Body - Exterior 2 05-18-2007 08:51 AM
1954 Chevy Pickup Door windows Boulderdesign54Chevy General Rodding Tech 4 05-17-2007 06:35 AM
