-   -   what are the diffrences between 10 bolts?? (http://www.hotrodders.com/forum/what-diffrences-between-10-bolts-136677.html)
hotrod389 04-08-2008 11:20 PM
ok excluding the style of suspension, and lengths of the rearends,
whats the diffrence bewteen a 8.5" ring gear c-clip to the one retained by bearings?
also, what carriers are for what gears in the said rearend?
i just installed a 10 bolt out of a 72 chevelle into my 68 tempest. to find a really odd glitch. the u-joint retainers, on the pinion yoke were not normal GM size.
after going throu a bunch of my stuff and then the neighbors 4 x 4 stuff. i found a set of retainers that work off of a dana 70 HD!
ive never encountered this problem in the 8 or so rearends ive swapped!
can anyone shead any liught on this?
troy.grant 04-09-2008 09:38 AM
Look on this sites tech section. while its really 4x4 applications, they really have everything you could ever wantto know about axles. hope this helps.
http://www.pirate4x4.com/tech
