what are the diffrences between 10 bolts?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2008, 11:20 PM
machinist & fabricator
ok excluding the style of suspension, and lengths of the rearends,
whats the diffrence bewteen a 8.5" ring gear c-clip to the one retained by bearings?
also, what carriers are for what gears in the said rearend?
i just installed a 10 bolt out of a 72 chevelle into my 68 tempest. to find a really odd glitch. the u-joint retainers, on the pinion yoke were not normal GM size.
after going throu a bunch of my stuff and then the neighbors 4 x 4 stuff. i found a set of retainers that work off of a dana 70 HD!
ive never encountered this problem in the 8 or so rearends ive swapped!
can anyone shead any liught on this?
Old 04-09-2008, 09:38 AM
Look on this sites tech section. while its really 4x4 applications, they really have everything you could ever wantto know about axles. hope this helps.
http://www.pirate4x4.com/tech
Head Bolts Canadian Charlie Engine 4 11-30-2005 03:04 PM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
10 0/0 theory dinger Hotrodders' Lounge 3 09-12-2002 08:14 AM
