what distributor for a 4.3L V6 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2005, 08:44 PM
gmwillys
I need to know what distributor to use on a non-computer, carburatored Chevy 4.3L V6. All I have at present is computor controlled unit. Surely, someone out there is making this engine work in a street rod.
Thanks
Old 12-31-2005, 11:41 PM
I have a solution, BUT, I cannot send you an e/mail with pictures so you can see what I suggest.
I do what you want all the time.
Old 01-01-2006, 01:39 AM
DoubleVision's Avatar
Find a unit out of a pre computerized chevy 229 V-6. rebuild it and drop it in.
Old 01-01-2006, 11:29 AM
4.3 distributer
I think you can build v8 hei distributer with 4.3 parts. I don't know if the modual is the same. I think an intake is more of a problem than a distributer.
Old 01-01-2006, 01:05 PM
200/229 are both odd fire engines, the 4.3 is an even fire.
Regular e/mail address would help, that way, I can send pics of a dedicated 4.3 even fire V6 dist you desire.
Old 01-01-2006, 05:31 PM
gmwillys
for ignition man
My email is hotrodfs@cox.net. Any help will be much appreciated.
Old 01-01-2006, 10:10 PM
You have mail, and pictures!
This should help you in what you are doing.
Let me know.
Old 01-01-2006, 10:51 PM
gmwillys,
If you are working on the same 3.4 engine that is in my Lumina I do not think there is a way to do this change over with stock over the counter parts. This engine has four camshafts on top of the heads so there is no way to drive a distributor. There is a place where a distributor used to be in the block, but it is now under the intake manifold and because of the oversized heads this hole can not be reached without taking the head off of the firewall side of the engine. I know this because the oil pump drive cover in these engines leak oil and can only be repaired by pulling the head off.
Good Luck
Scholman
Old 01-01-2006, 11:41 PM
Topic header "what distributor for a 4.3L V6 Chevy"
Key there is "4.3L V6". Not 3.4L
Very early 2.8L 60 degree 49 states specification first generation V6 engines used a non-computer, remote coil'd HEI. Citation and the first year 2.8 S10 that weren't California computer controlled had them. The 2.8/3.1/3.4L distributors won't interchange into a 299/229/4.3L V6.
Old 01-04-2006, 09:14 PM
smallblocker2's Avatar
L79 327 5SPD S10 '65GTO
Ignitionman, I'd like to see the goods to please. smallblocker@hotmail.com
I have a vortec 4.3 I was thinking of for my 4x4.
Old 12-22-2007, 10:19 AM
e-mail: calcombs@frontiernet.net I know that I can buy a after market aluminum intake & a 500 cfm carb, but haven't found a supplier for the HEI distributor. I have several old V8 HEI distributors that I could rob the parts from!
Old 12-22-2007, 10:26 AM
staleg's Avatar
Last journal entry: Hand brake
Accel 59110
Proform 67080
Mallory 470001 and 2770001
Old 04-03-2010, 11:26 PM
Bump... could i get some of the pics for making a dist. petapumkin@gmail.com
Old 04-03-2010, 11:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Let me know.
I tried to send you a PM, it's blocked on your end. The trouble w/displaying email addresses is it's an invitation to get spammed.
Could you unblock your PM?
Or, better yet, show the details here on the forum?
Thanks.
Old 04-03-2010, 11:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
Some 85-86 4.3L even-fire V-6 engines with federal emissions had a large-cap HEI distributor that still retained conventional mechanical and vacuum-advance provisions (NAPA remanufactured PN NRD481685, Hollander Salvage Yard Interchange No. 2221).
This was the stand-alone HEI, w/o ECM/feedback.
Ford vs Chevy question savman1 Engine 31 10-14-2008 08:13 PM
'98 4.3L transplant to '87 Chevy Pick Up? daveEM Engine 1 08-10-2005 10:02 AM
4.3 chevy v6 dist computer bypass help please 38 old coupe Electrical 1 08-02-2005 03:29 PM
FIRING ORDER FOR 3.1 93 CHEVY V6 DOBIED Engine 3 04-16-2003 03:12 PM
need to know if a 350 will hook up in a 2001 chevy with a v6 5speed trans fred taylor Transmission - Rearend 2 01-08-2003 04:56 PM
