what to do to change a 6 bolt lug to a 5 bolt lug pattern?(chevy) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2011, 04:35 AM
So i am not 100% if this is a rear end question or not, anyways, i have a 6 bolt lug pattern and i want to change it to a 5 bolt chevy lug pattern (5x4.75) my front end has that bolt pattern so i want to change the rear, i would like to use the existing housing and everything, do i just change the axels? or just the rotor with the correct bolt pattern? oh yeah i want to change it to disc brakes instead of the old drums.
Old 06-12-2011, 06:55 AM
SSedan64's Avatar
Some Axles are longer so you need to be sure which Rear you have. Also Axles & Drums can be redrilled for 5-lug pattern.
May find the Axle swap Info here>> http://67-72chevytrucks.com/vboard/s...d.php?t=157669 I know the Disc Brake Info is there.
Old 06-12-2011, 07:12 AM
Wiki Edits: 27
chevy discs
There are kits for converting to front discs that include a new caliper bracket and later car rotors. depending on the year of what vehicle . on some of the 50's pickups and cars, later year car 5 bolt rear axles and brakes were a bolt on.
Old 06-12-2011, 02:07 PM
sorry there i didn't put much detail, i ment to say that it is a 10 bolt rear end, and it is a 1956 chevy pick up. i just want to have rear disc brakes as well as fronts, and i already have an IFS that has the bolt pattern that i want, i just want the rear wheels to match.
Old 06-12-2011, 05:10 PM
Wiki Edits: 27
chevy truck brakes
I sold My 56 Cameo over 30 years ago. but I think car axles from the same year cars fit right in ... I think the 80's cad eldorado with rear disc brakes are the easy swap. I have a couple of the Eldo rear discs parts in boxes for future projects. The eldos have the 4.75 bolt patern It seems like some of the chevy axles need a little grinding to the axle pilot area so the center hole in the rotor will fit. The eldo rears have the built in emergency brakes. . there should be info on the classic chevy truck sites in more detail. I don.t know if you have to redrill the eldo caliper brackets to fit or not.
56 Chevy bolt pattern AllSteel34 Hotrodding Basics 1 08-01-2007 01:30 PM
nine inch with chevy bolt pattern Hogwild Transmission - Rearend 2 12-05-2006 03:05 PM
Did Chevy change the exhaust manifold bolt pattern on small blocks? STATUTORY GRAPE Engine 7 05-13-2005 06:34 PM
bolt pattern change opel gt AngliaBob Suspension - Brakes - Steering 2 01-13-2005 06:42 PM
Bolt pattern chevy 350 strokercuda Engine 2 12-02-2004 09:17 PM
