Moving to body/exterior..more appropriate there..
Sam
There's a gazillion posts about POR-15 on this site, pros and cons. The MOST important is using the product properly and going with the instruction. POR can be used as a covering but will fade after a time. Scuffing it down, using an epoxy primer over it before painting would probably be my choice, If I am wrong someone will chime in. If you're going to cover with an insulator, just cover it, the stuff is tough and if properly applied, shouldn't lift. As far as seams go, I wouldn't use POR, seam sealer should suffice, perhaps an epoxy primer before sealing, and like I said before, if this is wrong, we'll hear about that soon. POR is ok in some instances but is over-rated for everything, too much will cause headaches. Use it sparingly.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
I have done what you are doing to the interior side of the floor pan on a VW Beetle. No problems after six years. POR-15 will fade when exposed to sunlight. If it is used on an interior, and covered with DynaMat, carpet, door panels or otherwise not exposed to continuous long term sunlight, you will have no issues with it. Even if it does fade, the integrity of the coating is not affected. The areas that are exposed to sunlight can be overcoated with just about any product . Follow the POR directions for applying the product and subsequently overcoating it if you desire and you will have no issues.
See the main reason why I'm going with por-15 is, here in Hawaii the humidity is brutal at times. That's why I want something that'll stop the rust in it's tracks and protect the bare metal.
But I was wondering, por-15 is very pliable is it? So would going with a epoxy primer be a better bet, then go over that with a sound deadner, like dynamat or a bedliner type material?
| Car Cover...what to use | bentwings | Body - Exterior | 4 | 02-10-2010 10:14 AM |
| Bed cover | strummin67 | General Rodding Tech | 3 | 06-08-2007 06:56 PM |
| Value cover | juiced66malibu | Engine | 1 | 04-18-2007 12:18 AM |
| Best Car cover? | 428ho | Hotrodders' Lounge | 1 | 11-30-2006 02:35 PM |
| Bed Cover | squeaky4444 | General Rodding Tech | 1 | 10-19-2003 11:39 PM |
