I am running some mechanical gauges and was wondering what you guys do with the factory senders? I am replacing my oil pressure and water temp gauges and am going to be using the current fittings.
Do you guys just leave the current senders hanging, cut it, or tap another spot for the gauge sensors?
I try to "T" into oil connections and keep the sender/light. With coolant temp, there is usually another spot on the intake to put it and keep the light. Gauges are great but all of us get inattentive on occasion and what about if someone else drives your car? Keep the lights.
Thanks for the reply. I wanted to keep them but didnt think about using a "T" fitting. Should I be using antiseize when I plug these into the block? I dont trust teflon tape...
I hope you meant thread sealant for (oil and water) fittings. Never seize is used for nuts and bolts that you don't want to corrode (rust) together where they are exposed to the elements or with disimilar metals (steel bolts in aluminum).
Yes, use thread sealant like Permatex. T's work well for oil pressure but, IMO, not so much for coolant temp. I would find an alternate on the intake for that. If you don't have one close, some aftermarket Tstat housings have a fitting that works OK for a hot light, after warm-up, since they're usually on the wrong side of the stat.
My 454 is going to have both. In fact, I have plumbed in a dual (hot / cold) temperature switch with a blue light for cold.
I'm running forged pistons that run fairly loose when cold, and want a reminder to let it warm up.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
