If you plan on keeping the factory heads on it, and the bottom end factory stock, then I would add a Edelbrock performer plus kit which is the intake and camshaft, the cam is 204/214 duration and will give a good low end torque boost which a heavy camaro needs, also add a double roller timing chain while your in there, retain the factory Quadrajet carb. Next I would add a pertronix flame thrower coil and module, and a set of spiral core spark plug wires routed correctly. then add a set of headers and free up the exhaust some with a good muffler, top it off with a K&N airfilter, these small mods won`t break the bank and will make your camaro not only have more power but better mileage.
