What do I do about the abs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 09:16 PM
gROCERYgEtteR's Avatar
I have a Ford 8.8 with rear disks and ABS, What happens if I just run it like they are not there? Plug the sensor hole and call it good? It is for a '40 Plymouth and I would really like to not deal with all the junk just for ABS. Any insight would be appreciated.
I understand there will be some proportioning involved ,to hinder rear lock up, but what other problems may I face?
Old 09-19-2005, 10:30 PM
So the only part you have for the ABS is the holes for the sensors in the rear?
If so just set it up like you would a non-ABS car w/ 4 wheel disc...it won't know the difference.
Old 09-19-2005, 10:41 PM
302 Z28's Avatar
ABS is controlled by the vehicle control module through a motor driven master cylinder that pulsates the master cylinder. If all you have is the rear brakes they are no different than a standard disc brake assembly.
Vince
Old 09-19-2005, 10:52 PM
That is kinda what I was hoping for, but do I need to concern myself with any of the left over components? If not used are they going to cause problems? should I pull the pads and adjusters and such, or do they need to stay in there and treat the assembly as if were still abs?
I have all the parts that are attached to the rear, cables, sensors for the, excuse my lameness the gear thing, and the guts.
Thanks by the way!
Old 09-19-2005, 10:57 PM
The shoes, adjusters, and cables aren't part of the ABS. They are the e-brake. The only ABS part is the "toothed wheel" and the sensors/wires. The toothed wheel won't get in the way of anything so just leave it. You can remove the sensors if you want and plug the hole...or just cut the wires off the sensors.
Well, hold on a second! I don't have a master cylinder or booster yet. So this is a guess but if I go get the right parts, which would be booster, master and??? to get the thing back on line would it be worth the cost and effort?
Old 09-19-2005, 11:29 PM
Well, thank you for the clarification and help, to keep things simple I think I will put the sensors back in cut the leads and be done with it. But when I need help with that e-brake I may look you up.
Retrofitting ABS brakes? Siggy_Freud Suspension - Brakes - Steering 3 11-09-2004 03:29 PM
bleeding an ABs module lonewolf3197 Suspension - Brakes - Steering 4 04-19-2004 02:24 PM
ABS Brakes 85 chevy p/u Suspension - Brakes - Steering 4 11-27-2003 01:19 PM
ABS on non-abs equipped cars; abs kits Fragzem Suspension - Brakes - Steering 0 10-29-2003 02:06 AM
1991 Sonoma ABS Question bluesman123 Suspension - Brakes - Steering 5 05-13-2003 08:34 PM
