What do i need to get going sbc dist. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2006, 07:48 PM
All right guys what i've got is an accel distributer 43107A I bought it cheap. it
has a mechanical tach drive and two wires running out. it came with plug wires
and a super coil for 75 dollars. what i need to know is how to switch from a
pointsdistributer to this. Or to know if it;s not worth it. The only ting thats got
me worried is that it didn't come with a module box and there like 200$. Any help
sure would be appriciated .
Old 02-19-2006, 09:53 PM
OK, follow me closely, please, I am going to describe ywo different Accel dists that appear the same from the outside.
First operation, pull the cap off the dist.
Take a look inside and see if there are two sets of points and a points cam. There should be two distinct point wires, one from each set of points to outside the dist, then, a ways down one of the two wires, a connector. both wires should go to a ring terminal at their ends, ONE ring terminal. There should also be a condenser on the outside of the dist, its one wire going to one set of the points only
If so, that dist is a replacement dual point Corvette dist made eons ago.
The other type is an electronic system, and will appear different inside.
In this system, there will be a magnetic pickup, only one, should be black, looks like an oval racetrack sitting on its end, with a steel bar in its center. That would be a magnetic pickup for electronic ignition. It should have two wires off one end of the oval, going out to a two wire connector, if it is still there. In the center of the dist, there would also be a star wheel with 8 projections.
Which one do you have, please.
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
changing from points dist. to electornic dist. what to change? IHAVECHEVYPARTS Electrical 1 12-21-2002 09:20 AM
