What do I need to monitor running usage? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2005, 11:53 AM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
I know I read somewhere about adding a timer to the compressor circuitry.
What type and where would I buy a timer to add to my compressor so I can track the hours that the motor and compressor are on?
Also I would need some insight on how to wire it into the current circuit.
ThanX
Old 12-08-2005, 08:25 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
all you would need is a hour meter commeted to the power to the motor after the auto switch
http://content.honeywell.com/sensing...corp/cat1.asp#
might as well get a auto dump for the bottom of the tank too
SR66
I'm not prejudice, I hate everyone
"SlowRide66"
"Illegitimis non carborundum"
Old 12-08-2005, 10:34 PM
58Chev's Avatar
SR66
Exactly what I was looking for.
ThanX I was looking at one of those auto drains..
Old 12-09-2005, 10:00 AM
Rob Keller's Avatar
Wiki Edits: 38
yea man those are sweet your welcome
that was one of the 1st things I used to do when going into a new shop/job is drain the air tank and check the oil in the unit
I've drained some that took over a hour to get it out the water running out into the parking lot
then off to fix the leaking air hoses MAN that drives me nutz
all day long SSSSSSSSSSSSsssssssssssssssssSSSSSSSSSSSS
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSsss
sssssssssssssssssssssssssssssssssssSSSSSSSSSS
SSSSSSSSSSSSSSS
SR66
"SlowRide66"
Abnormal Fuel usage Cruiseomatic Engine 14 08-31-2004 11:29 PM
Advice on oil usage after break-in. bowtieorbust Engine 2 02-28-2004 09:07 AM
flywheel usage Ned-the-wrench Transmission - Rearend 2 12-03-2003 02:09 AM
