What do i set my roller rockers at? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2010, 11:59 AM
blown67's Avatar
I have edelbrock heads with bte roller rockers on a blown sbc and i was wondering what the lasch has to be set at with this motor?
thanks
Old 09-10-2010, 01:44 PM
327NUT's Avatar
Did you consult your cam company and ask them the specs?......or read the cam card? Are they solids or hydraulic lifters?
Old 09-10-2010, 04:00 PM
blown67's Avatar
its a reed cam nd i cant get ahold of them i bought this car about 2 months ago so i dont know much about it ... it is a solid reed cam
Old 09-10-2010, 04:30 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
You'll be safe settin' 'em at 0.025" hot (0.019" cold) until you find out more information from the mfg or someone with a Reed timing card.
http://cranecams.com/?show=faq&id=4
Old 09-10-2010, 07:53 PM
ericnova72's Avatar
More for Less Racer
Reed Cams is out of business, a victim of the current poor economy. Techinspector has a good basic starting point.
Old 09-11-2010, 03:19 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
thanks
If the engine is all together and running, before you do anything to change the lash, measure what it is now- both cold and hot.
That way you will have a baseline to use, and that will also tell you pretty darned close to what the lash should be. If the intakes are all right at 0.022" and say the exhausts are all hovering around 0.025", there's your answer.
The only way this wouldn't be correct is if the valves hadn't been lashed in a LONG time, if there's a lot of wear going on for some reason, or if the lash was changed from having run a "lash loop".
Or if it was changed on a whim by the PO. But that would be very unlikely.
Roller Rockers Question - Roller Pin Coming Out leejoy Engine 9 11-27-2008 12:52 AM
Chevy OE Roller Timing Set 307malibu Engine 23 06-07-2008 07:01 PM
Are 1.6 roller rockers worth the effort streetmaster42 Engine 1 12-24-2007 08:36 PM
Roller Rockers for a Stocker? coda618 Engine 4 10-28-2006 08:51 PM
1.6 roller rockers?? tiresmoke55 Engine 9 09-07-2006 01:53 AM
