What do impala brakes interchange with? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2009, 04:38 PM
Our local parts store only goes back like 25 years and not even that far on some things. Any of you know what vehicle made in the last 20 years by chev would use the same rear drum shoes as the front of a 69 impala. I'm thinking maybe s10 but wondering if somebody has cross reference. Thankyou all
Old 10-07-2009, 10:53 AM
Start by finding a real auto parts store. Even Advance Auto has a listing for this car. So does Rockauto.com. At a minimum, go on line, get the correct part number, and have your local store search for that part number.
Old 10-07-2009, 12:55 PM
If I remember right they were 11X2 and the set number was, not sure, 263 It's been awhile. Age and memory you know or will haha Take you old ones and compare.
Old 10-12-2009, 01:19 AM
They should have a paper catalog with listings that supplement what's in the computer. They should also have somebody that knows how to use the paper catalog.
Old 10-20-2009, 10:02 AM
deadbodyman's Avatar
Wiki Edits: 11
95 impala has a 12" rotor that I used in a 80 camero sub frame but in a 69 you might have to use the A frames and spindle then you might have a problem with the linkage which wouldnt be a problem with a rack & pinion all junk yard stuff. its just bolt on stuff with an 80ish camero (Without the rack)not to sure with the 69 but there is a kit available for 69 camero, it should be the same.....www.impalaparts.com ... Caliper mounting brackets 95.00 pr calipers 39.00 ea, rotor 85.00ea., but you can get the calipers and rotors at a discount auto supply cheaper.The mounting brackets are the important piece to get if you keep your spindles....pt#5964BCMB tel#1-800-8467252
Old 10-23-2009, 06:19 AM
rachet ralph's Avatar
i had a 69 impala it had factroy disc, an was 5"x 5 bolt size i would look into seeing if like later 80's cadillac spindles an stuff would work out for you if remember right 69 was a front mount steering box an i feel be your closest cross over for your impala
Old 10-23-2009, 04:49 PM
Last journal entry: frame build
My 69 Impala also had discs on the front. My Uncle was mad cause his 69 Caddy didn't.
Manual disc brakes galaxieguy3 Suspension - Brakes - Steering 6 07-21-2009 06:49 PM
Need Help With My Brakes S10 Racer Suspension - Brakes - Steering 4 01-18-2009 02:00 PM
65 Impala Drum Brakes Question EazyDuzIt102 Suspension - Brakes - Steering 2 08-09-2005 04:16 PM
power brakes and power steering on a '63 impala SS Benni520 Hotrodders' Lounge 2 10-14-2002 09:49 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
