What to do with these headers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2009, 10:42 AM
So I am building my 48 chevy with a brand new zz4 crate engine and I have new coated sanderson headers. It says not to break a new engine in with them but I figured since it was a roller cam I should be able to start it and shut it off after 30 seconds and let them cool. I was going to have a timing light ready to go as soon as it starts. It will just be tough to reinstall them on a fresh car if I try use other manifolds. Any suggestions?
Old 12-06-2009, 11:00 AM
speedfreak2's Avatar
WrenchingAce
I've broken in plenty of engines with ceramic coated headers with no ill effects. All you need to do is jet the carb as close and you can and get the timing in the ball park, preferably slightly advanced, before you start the engine. You already have the timing light hooked up and ready to go and you do have a roller cam so most of your problems are taken care if right there. Just start the engine and get the light on the timing asap and you should be just fine.
Old 12-06-2009, 11:12 AM
38mike's Avatar
ceramic headers
Okay, so I'm naive. What the heck is the (potential) problem with using ceramic headers on a new engine?
Old 12-06-2009, 11:15 AM
WrenchingAce
Some people say that it might "dull" the finish. I say big deal...after years of use the shine will go away. I think that's the issue anyways. Maybe others have had different issues.
Old 12-06-2009, 12:27 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Most flat-cammed engines need to stay at fast idle for 20 minutes. If the jetting is off or the timing isn't perfect the headers get screaming hot. Ceramic coated headers get their final cure from exhaust heat, so if it gets too hot it can damage the ceramic coating.
Its not a given that they will be damaged, but its a common enough problem that it voids the warranty.
Old 12-06-2009, 04:35 PM
Ya I think I will just try that then and have thetiming light ready to go. Should be ok. Thanks.
Old 12-06-2009, 05:17 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Originally Posted by lt1tyrell
....but I figured since it was a roller cam I should be able to start it and shut it off after 30 seconds and let them cool.
I think you'll be fine, as you say the roller requires no break-in so if the engine starts to get a little warm just shut it down and let it cool off.
Old 12-06-2009, 08:37 PM
001mustang's Avatar
If you have an IR gun you can monitor the header temp; If header temp starts climbing above 1000F then you can start to sweat.
Do your home work and try to get carb preset close. You can quickly adjust idle mix screw on the rich side; careful not to foul plugs.
Quickly verify timing as others said.
I set fans in front of radiator.
I open radiator drain and have a steady stream of cold water going into radiator.
I mist radiator fins with water.
Old 12-06-2009, 09:00 PM
DoubleVision's Avatar
The fans are a good idea if you were going to do a flat tappet cam break in. But since it`s a roller you have no worries. I bought jet hot coated hooker super comps for my cutlass in `07. I didn`t have to do a break in either being it had a roller cam, no matter, after a month you could see the rust under the nice shiny finish. almost 500 bucks for a set of headers and they still rust, can`t win.
Old 12-06-2009, 09:37 PM
001mustang's Avatar
Mr. Vision,
I sure would love to see a picture of your damaged jet hot ceramic coated header damage. I have worked with ceramic coatings and they are tough. Takes forever to remove with aluminum oxide blasting media. I understand rust popping out near crevices. Did rust pop through the smooth surfaces? So far so good with my JBA ceramic coated SS headers.
Old 12-06-2009, 10:55 PM
curtis73's Avatar
Wiki Edits: 16
Mine discolored when I used them on a 454 break-in, but I didn't care about looks. I was more concerned with longevity of the coating. The outsides of the downturn right after the port got chalky. About 20k later the ceramic started to show little hairline cracks.
What has been your experience with headers compaired to stock exhaust manifolds?? Jim Weeks Engine 10 10-06-2012 11:21 AM
Ceramic Coated Headers mike bryan Engine 15 09-02-2010 04:47 PM
Can't find headers for my 2002 GMC Sierra Mad Maggot Engine 11 09-17-2008 08:19 PM
making custom headers??? aztek_warrior Engine 2 07-11-2006 10:13 PM
Headers are done 78 monte Engine 10 09-04-2004 02:52 AM
