what do these numbers on my block mean? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2005, 09:49 PM
bigwildgrin's Avatar
Rooster
okay, I on the block ID pad there are these numbers: TO11OIU (I know the IU means 435hp with aluminum heads, but what does the rest tell me?) and then ten digits that the last six are the VIN # of the car, but what are the other four digits telling me? thanks a bunch.
Old 05-19-2005, 03:17 PM
Block numbers
T0110 IU
T= TONAWANDA
01= JANUARY
10= 10th DAY
IU= 1967 or 1968 Corvette 427CI, 435HP manual trans, Special High Performance.
VIN Code Format
The vin code format is stamped onto most engines. The format consists of divisional identification number, model year, assembly plant designation and vehicle serial or sequence number.
In 68-69 model cars, the serial (VIN) number of the car the engine was installed in is stamped next to, or under the engine code ID.
Starting in 1970, the serial number is stamped either above the oil filter, somewhere on the block pad (in front of the cylinder head), or on the transmission flange somewhere. Chevrolet issued technical service bulletins to indicate which engines were to recieve a vin stamp, so who knows what could have happend (or not happened).
VIN code format Example: 13N100001
(1 = Chevrolet, 3 = 1973, N = Norwood, 100001 = Production sequence of vehicle VIN)
Hope this helps you out. I'd love to have that engine.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
Tall block Chevy 366-427 need some numbers? 81elcamino Engine 3 01-21-2004 05:48 AM
Filling Block/ Hard Block??? camaroman7d Engine 8 01-15-2004 07:30 AM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 07:06 AM
