What to do for winter storage - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2003, 11:12 AM
polcat500's Avatar
New Member
Puting My 79 grand pric away for winter and breaking out the snowmobiles. What are some things I should do to her to help her hibernate?
Old 10-22-2003, 11:23 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
I can never let mine sit for very long!!! But when I have to I make sure of the usual- fresh oil change, antifreeze change or at least check for freeze point and level, I put a 'battery tender' on the battery to keep it up to charge, and I put some gas stabilizer in the tank with fresh gas. You'll get a lot of suggestions on this- I guess it depends on the severity of the winter and the actual time it will be left. Don't forget to clean him, polish and wax to protect the finish also!!
Old 10-23-2003, 08:55 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Put some Sta-Bil in the gas along with some Marvel Mystery Oil.
It keeps it fresh, park it with a full tank.
About once a month bump it over to change the valve springs from getting weak esp. if it has a big cam and keep the seats from rusting.
If its outside put some baggies over the exhaust pipes to stop the wind from blowing thru.
Luv the smell of NITRO in the morning.
Old 10-23-2003, 11:21 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I drian all fluids, close the valves, fill the chambers with ATF, tape off the ports, set the carb into a bucket of WD-40, loosen the belts, jack it off the springs,cover the pipes to keep critters out, cover it with a water tight cover and store it in the shop.
Old 10-25-2003, 06:52 AM
Tazz
Winter Doun time
Clean it, then wax and polish the chrome. The battery tender cable its a great idea and makes keeping the battery charged easier too. The gas stabilizer is a good idea, Marvel Mystery oil or Sta-Bil, just do something with this stuff they call gas nowadays, its noting like it once was and will need stabilizing. I start mine up and let the engine come up to temperature, I don't just turn it over, I want to hear that engine run a while. I do not drain all the fluids, but an oil change and full tank of gas is a good idea. I don't pull my carb or loosen the belts and I park it on carpet samples and run a fan under the body to cut down on condensation.
Todd
Rat Rods Rule!
