what do you think? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2007, 09:06 AM
What Do You Think? Is This A Good Deal
IS THIS A GOOD DEAL ?? i am thinking of buying this truck for appx 5000.00
1985 V8 Chevrolet S10 Pickup.This truck is the cleanest S10 you will ever find anywhere. This is an all out strip drag truck. It has a 350 motor, 350 trans, and a ford 9''. It is painted flat black. I have listed the full specs below. It is 100% complete, all parts have been professionally installed, and it is ready to race. This is a turnkey drag truck. It needs absolutely nothing, just gas and an experienced driver. This truck is NOT for someone who does not have any experience racing or driving. It is extremely fast. This truck ran 6.30 in the 1/8 mile the first time out right off the trailer. It needs to be fine tuned to a driver and it will run faster. It runs on 110 octane because it is 12.5-1 compression. It has a 150 shot of nitrous. It will run on 93 octane but will spark knock. I currently have it registered and tagged here in fort myers and drive it on the street. Although it is not very streetable. Cannot be driven in the rain, does not have wipers, horn, turn signals, and probably has other things that you could get pulled over for. So check your local laws first. This has been my project for the past year and all work has been done in that time. Not to mention the large amount of time it took. The frame has been completely stripped and painted. Evey nut or bolt that is not needed has been removed. It has been converted to manual steering and manual brakes. All the body work was done before it was painted. Everything is straight. I am selling because i am moving and cannot afford to bring it with me. I have the title, it is clear and ready to be transfered.
Chevy 350
4 bolt main
bored 30 over to 355 cid.
12.5-1 compression ratio
203 heads- 202, 208 valves
Eagle I beam rods
Steel crank
Comp Cams 306S .555 lift .306 duration
MSD Pro Billet distributor
Edelbrock Victor Jr. aluminum single plane intake
Holley 4150 carburator
STAHL S-10 conversion fenderwell exit headers (with adapter flanges)
Accel 8mm wires with Accel Supercoil new ACdelco plugs
New GM starter
New 1 wire race alternator
Billet throttle cable bracket
Chrome valve cover, timing chain cover, water outlet, valve covers and air filter
COOLING SYSTEM
BeCool S10 aluminum conversion radiator
BeCool Radiator Cap
New hoses
Cast water pump
New Slim Line 14 inch electric fan
Custom restrictor plate(1 1/2 inch opening) to replace thermostat
Jaz Catch can
TRANSMISSION
Chevy Turbo 350
Reverse manual valvebody (reverse meaning standard shift pattern P-R-N-1-2-3)
B&M shift kit
4000 stall torque converter
Auxillary Cooler with braided A/N lines from transmission to cooler
Braided dipstick
SFI approved zinc plated flywheel
Cheetah SCS slap shifter (one of the bets shifters out there, you just slap it forward)
REAR AXLE
Ford 9 inch Housing
4.10 gears
Moser Street Strip Axles S/S
Drum brakes
New bearings and New axle seals
REAR SUSPENSION
Leaf springs with 2 leafs per pack
Competition Engineering Slide-A-Link Bars (Completely adjustable)
Newer Stock style shocks
Newer Brake lines
FRONT SUSPENSION
S10 Extended cab coils
Belltech 2 inch drop spindles
Newer bearings and brakes
New sway bar links
Extended steering stops to clear headers (tires do not rub headers)
Newer Brake lines
CHASSIS
4 Point rollcage (welded to frame for strength)
Stock S10 single cab shortbed frame completely stripped and painted
Battery mounted in Bed with Power Cut Off Switch in bed
Stock bumpers painted flat black to match
Weld Racing Draglite rims front and rear
Mickey Thompson ET Street 29x12.50 Slicks
Converted to manual brakes
New Adjustable proportionong valve
New manual master cylinder
Brand New GM Manual Steering Box
FUEL / NITROUS
14 Gallon fuel cell, foam filled, rear sump, GM sending unit, mounted in bed
A/N lines from fuel cell to carburator
Fuel splitting blocks and pressure regulator mounted under hood
Nitous fuel pressure gauge mounted externally in front of windshield
Braided A/N lines to nitrous fuel solenoid
2 seperate fuel systems/ 1 for nitrous and 1 for naturally aspiration
Aeromotive fuel pump with built in pressure regulator and filter
Holley blue pump with Aeromotive filter
NOS 150 shot plate injection nitrous kit
10lb Nitrous bottle mounted in bed and FULL ready to race
Purge fitted with copper lines and comes out in front of windshield
ELECTRONICS
MSD 6AL ignition
MSD Digital Retard
Autometer Sport Comp Fuel level gauge
Autometer Sport Comp Voltmeter gauge
Autometer Sport Comp Water temp gauge
Autometer Sport Comp Oil pressure gauge
Autometer Sport Comp Fuel pressure gauge
Autometer autoguage Tachometer with Shift light
All gauges light up when lights are on
100% proffesionally wired extremely clean wiring PERFECT!!
175 Degree thermostat switch turns on electric fan ( can be manually turned on by a switch)
2 relays and fuses for each fuel pump ensure pumps are always running
Head lights(high and low beams) and brake lights work
EXTERIOR
Painted Flat Black no clearcoat for east touch-ups
Bumpers painted to match
Harwood cowl induction hood
Fast Lane Tailnet
INTERIOR / SAFETY
Cobra racing Seats
4 Point harnesses for driver and passenger
Custom aluminum dash and center console
Grant Steering wheel and Grant Adapter
New carpet
Tinted Windows
Manual windows and door locks
Tilt column
Coil mounted inside away from heat
Inerior completely stripped and sanded and painted black
Newer headliner
Old 03-10-2007, 07:23 PM
Old 03-10-2007, 08:03 PM
Mustangsaly's Avatar
pics ?
Mustangsaly
Old 03-10-2007, 08:14 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Definately need to see some pictures.
Old 03-10-2007, 08:16 PM
Old 03-10-2007, 08:32 PM
Old 03-10-2007, 09:10 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
looks like a good deal to me. If I wanted it I would buy it.
Old 03-10-2007, 09:18 PM
yeah i thought 6.3 in 1/8 for under 5000.00 was a good deal just looking for opinions. thanks i know i couldnt build this for under 15000.00
