What do you think of this 383 sbc combo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2005, 03:54 PM
New Member
4.030 x 3.75
5.7 lunati rods
lightweight trw flat tops
.040 quench
67 cc Canfield heads
approx flow:
250 @ .400
260@500
260@600
250@700
cam solid flat tappet
256 / 270 @ .050
.545 / .578 lift
112 lobe sep
10.6 : 1 comp
Victor Jr
800 dbl pumper
300hp Top Gun plate
Th400 w/ brake
3700 converter
built 12 bolt with either 4.10s or 4.56s
28 or 29x10 slicks
3200 lb 72 Nova
I want to be able to run on pump gas on the motor with a separate fuel system for the spray. My goal is to run as fast as I can on the bottle, and everything else can is not so important.
Old 01-05-2005, 04:50 PM
My guess it should get lots of attention and go 9's.
Old 01-05-2005, 05:43 PM
Mighty Mouse S-10's Avatar
Cleverly disguised as grownup
Last journal entry: Hollman & Moody
Good luck with that pump gas thang. Compression may be a little high for that. Do you have 91 or 93 octane?
Old 01-05-2005, 07:19 PM
New Member
93 octane in Dallas near sea level. I had the shortblock together before with the same duration cam with only 500 / 515 lift. and 72cc iron Sportsman heads. I put several bottles through it without ever using race gas. I think that part'll be fine.
Old 01-05-2005, 08:28 PM
johnsongrass1's Avatar
Race it, Don't rice it!
.545 / .578 lift?
These with 1.5. Use a rocker with more ratio so you can lower the cam duration. It won't be as hard on valves and live longer between refreshes.
Old 01-06-2005, 09:36 PM
New Member
Explain how more ratio is easier on parts.
