Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what do you think of a 4 bolt main #511 400 SBC Block ?
Old 03-04-2008, 10:24 AM
Mustangsaly's Avatar
Mustangsaly Mustangsaly is offline
what do you think of a 4 bolt main #511 400 SBC Block ? The 400SBC I bought is a 4 bolt #511 block, it has a worked over set of #187 camel hump heads and is 10.5 or so CR and has a healthy bump stick. it runs real good.
I just heard the 400 2 bolt mains were a stronger block. this isn't a all out strip car but a 16 yr old will be the owner operator. I didn't pay a lot and I got some nice pieces like the heads & M21 ect.
its complete and going in a father son 74 Camaro project. this is a 74 Camaro that will have this 400SBC & M21 4 speed tranny with frame connectors and a 10 bolt posi. I'm guessing the gears are 308s or 342s. kinda hard to tell as the clutch was almost completely out of the car, so it wasn't drove much with the 350 T10 in it. I put a new water pump on the 400 and just had the 4 core radiator gone through. going to run a 6 blade mechanical fan with the factory shroud. and it's an a/c car but most all the a/c stuff is gone, and there no money now for a/c so I think I will pull the a/c condenser till we have all new a/c stuff. then I will go back with a/c components big enough to run a R134a system. I have a complete serpentine belt system with a new R134a a/c compressor.
Mustangsaly
