Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What do you think of HID headlight kits?
  #18 (permalink)
Old 03-29-2013, 04:03 PM
xxllmm4 xxllmm4 is offline
Do the lights say DOT approved ?? If so lets see the paperwork.
Customs Seizing Imports of Illegal HID Conversion Kits | Specialty Equipment Market Association
This is from Washington state... All 50 states must comply with this law so in other words they are NOT legal ANYWHERE in the USA. If you want to call it a myth go ahead but at least look into it.
Are high intensity discharge (HID) conversion kits legal?
No, in order for a headlight to be legal for use in Washington State, it must conform to the Federal Motor Vehicle Safety Standards (FMVSS) 108 requirements for headlights. The National Highway Traffic Safety Administration (NHTSA) has concluded that it is impossible to produce HID conversion kits (converting a halogen system to HID) that would be compliant with FMVSS 108.
Halogen equipment uses an electrical current to heat a metal wire coil filament to incandescence, while the HID conversion kit's light source incorporates a discharge arc to produce light. HIDs require a ballast for operation. Under FMVSS 108 Section S7.7 (replacement light sources), each replaceable light source for headlamps must be designed to conform to the dimensions and electrical specifications for the headlamp source it is intended to replace. For example, if an HID kit is marketed as replacing an H1 light source, then it must match the H1's wire coil filament size and location, the electrical connector size and location, and the ballast design for use with an H1 light source (which is impossible since there is no ballast).
NHTSA believes this equipment presents a safety risk to the public since the kits can be expected to produce excessive glare to oncoming motorists. In one investigation, NHTSA found that an HID conversion headlamp exceeded the maximum candlepower by over 800 percent.
The Following User Says Thank You to xxllmm4 For This Useful Post:
LATECH (03-29-2013)
