what do you think of this HVLP set ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2012, 05:45 PM
wmwise's Avatar
De Oppresso Liber
http://www.sears.com/sharpe-manufact...4&blockType=G4
Looking for a budget set of HVLP guns to shoot single stage paint on my old project truck.
Thanks in advance for your advice and opinions !!
Bill
Old 06-20-2012, 06:26 PM
My advice to you is get a conventional air spray gun with gravity feed (cup on top) and stay away from low cost HVLP guns if you don't have to use one. You can get a Sharpe Finex FX2000 for about $120. I spray in my garage and fought orange peel in my epoxy, primer and single stage urethane for about a year and purchased three HVLP spray guns trying to get coatings to spray on smooth and slick. Then I tried a friends old SATA RP2000. The RP is for reduced pressure. With that gun I sprayed my first slick no need to wet sand paint job.
I then purchased a conventional air cap for my DeVilbiss Finishline 3 HVLP spray gun and now it sprays great (the air cap was $40 and inlet pressure is now 35-45psi and air consumption is now about 9.4cfm). Yes you will have more overspray and you will have have to move faster when painting, but it is so nice to not have to wet sand everything you paint to get a smooth finish.
Old 06-21-2012, 04:52 AM
wmwise's Avatar
De Oppresso Liber
Thanks for the great advice ! I will look into the FX2000
hvlp set up theotherbarry Body - Exterior 4 05-25-2011 03:04 PM
How to set pressure on HVLP...help, please. onpyramid Body - Exterior 0 04-29-2010 12:37 PM
MaxAir W989K HVLP Spray Gun Set MaxAir W989K HVLP Spray Gun Set lax54650 Body - Exterior 0 02-13-2010 01:23 PM
HVLP air pressure set with trigger pulled? rpacker Body - Exterior 12 08-23-2009 08:19 AM
