What do you think it will run? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2008, 06:05 AM
DarknessSpawned's Avatar
God Of Lightning
Motor is Done.. What do you think it'll run?
First Gen S10, Shortbed.
Motor: 355
Juice: No
Timing: ~36 total
Compression: ~9.5-1
Air Induction: Cool air setup, (2 snorkels/air tubes)
Air Conditioned: yes
Carburetor: Holley 650, Vac.2ndaries, 2" 4-hole spacer
Intake: Performer EPS for vortecs
Heads: Refreshed Vortecs
Head Extras: 1.5 roller rockers
Camshaft: Comp xe268h
Cam Retard/Advance: Installed @ "0" (comp says 0 has +4 ground in already)
Headers: Hooker Supercomp Long tubes
Exhaust: 2.5 to dynomax/thrush welded muffs
Transmission: 700r4
Converter Stall Speed: 2500~2800 w/lockup
Tranny Extras: Transgo kit, ratchet shifter
Rear Gears: 3.42 at first...... 3.73's when they break maybe.
Posi-Trac: Working on it, So lets say YES
Tires/Slicks: MT e/t's 275/50/15
Traction Adders: None right now, Workin on bars and tank in the bed.
Weight: Standard first gen s10 weight.
What do you think it will go?
Power guestimate, E/T's....
Ive been askin around about it.
Share your opinions on it....
Hoping to be able to bust on the 5.0's and cold air pre-ludes
edit: Its gonna be a semi-daily driver when Im not drivin the wife's car.
Thanks
Old 10-24-2008, 07:24 PM
72 grabber 51F-1 65 chevystang
Assuming it hooks good I would guess high 7's or low 8's in the 1/8 mile.
Old 10-24-2008, 07:29 PM
dh79's Avatar
Stock 5.0's will be no problem.
Mid 13's is my estimate.
81 Grand Prix, 355, 700r4, 8.5" 4.10
64 Oldsmobile Jetstar, all original
Old 10-25-2008, 02:53 AM
Sickpuppy22's Avatar
Mine did 13.9 @ 96 mph with th350 and 3.73's with 27 inch tall street tire, was hard to hookup though. With a 4.11 gear and your 700r4 and slicks id say mid 13' and maybe even high 12' but with tho low gears maybe low 14's
Old 10-25-2008, 08:23 AM
Buick Hybrid Guy.
Estimates here are close.. .You should have no problem running low 13's to high 12's (I'd guess closer to high 12's) 107mph my guess. (I look at MPH more than ET)
Had the same setup back in the day.. Stay with the 3:42's... Don't need much gear with that weight.. and if your going to spray it later it'll help to have a mid gear.
Good luck!!!
Scott~
Old 11-03-2008, 11:48 PM
God Of Lightning
Good luck!!!
Scott~
Sweet truck
What kinda horsepower numbers do you think my combo can pull?
If you had a similar setup, What was yours pushing?
I have almost the exact setup as this build... Theyused the same cam
and heads as I did on a basic build....... Except mine is bored 30.
Vortec 350 Chevy High Performance
I feel like I should be getting more. I mean is this a quick combo.
After all this work I dont know why I couldnt bust on most
daily driven stangs, new and old, Assuming they have the normal
mods to their daily driver. And all these spiked hair kids in
their cold air intake hondas...
And z28 camaros....
Am I missing something here..............
wire me up tbelltim Electrical 1 05-18-2007 03:07 AM
HELP , My Firebird is dead IGENFIREBIRD Electrical 29 04-23-2007 04:24 PM
how to build 454 to run propane with 600+HP? propaine rockcrawler Engine 0 03-04-2007 11:12 AM
how to run heat riser tubes? matt167 Engine 1 09-12-2006 06:49 PM
Engine and tranny run in Wheels427 Engine 6 03-16-2004 09:34 AM
