Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What do you use for clear coat
  #16 (permalink)
Old 02-28-2011, 07:32 AM
deadbodyman's Avatar
deadbodyman deadbodyman is online now
Wiki Edits: 11
Originally Posted by Aboven
Thanks guys for the help again I am going to order some spi and see how it works out if there are any tips
Not really ,just spray it like you want it to look right from the git go. I use 2 coats for everyday work ,more on restos with sanding between recoats.The only problem I 've ever had was when I left a partially used can of hardner on the shelf for a few weeks and although I knew it was a little thick I used it anyways ....Man that stuff dried quick ,I could barely get around the car before it was dry.....The cure (I called the SPI hotline) put some mig welding gas in the hardner can before closing the cap...The gas is heavier than air so the air wont effect the hardner...But that trick works on ALL hardners...
I've also been concidering pro-spray for a base and SS ,I've talked to quite a few pros and everything I hear is positive...Cant wait to try it...
