What do you use to cut sheetmetal - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2006, 01:48 PM
cab cab is offline
Hello All, as I begin "accumulating" (i.e. that's grom the old gaelic term whihc loosley translates to "spending money on cool tools") tools perparing for the bodywork phase of my project (67 Firebird) I was wonderign what tools you recommend for cutting sheetmetal (as in "cutting sheetmetal out of that ruster quarter panel for a patch"). I was at my local Northern Tool store staring at 4" electric grinders (which could have a cutoff wheel instead of a grinder), air "scissors", nibblers, little die grinders (same as above I guess for a cutoff wheel). Any kind of nibbler looks like it would distort the metal to me, but cutoff wheels actually remove a bit of metal.
Opinions?
Thanks,
Chris
Old 07-11-2006, 02:33 PM
An air chisel with a panel ripper bit and also a wide but thin chisel gets used for quick and rough trimming and spot weld seperation. Plasma cutter is also fast but not real precise. A 3"X 1/32" cutoff wheel is used for precision cuts. Nibblers and snips also have their uses. But the tool I use the most for precision cutting for patch panel work is an airsaw. The airsaw does nice work for following scribe lines and will turn a .5" radius with the right blade and no distortion.
Old 07-11-2006, 03:26 PM
The more the tools the better. I would say for cutting realitivly thin sheetmetal out for patches I use my electric nibbler the most. There is times when a cutoff wheel or an air saw is used to. and a airhammer with a cutter bit will cut fast too. For thicker plate, a plaxma cutter can't be beat. Its a little out of my budget, but we have one at work. Cutting through plate with the plasma cutter takes minutes instead of forever with air tools. When still sort of new at work, I was using a sawsall on some 3/16 inch metal trying to cut out a large rectangle as it caught and jumped around in spots, the boss tells me they have a plasma cutter. After 5 minutes to grab a piece of angle iron and clamp it on for a guide for the cut, the actual cut took hardy any time and was a nice straight cut.
Old 07-11-2006, 03:36 PM
proper tools.
For thin sheet metal, an air driven cut-off wheel is probably best. Good control and it won't bend, twist or distort the edges. The air driven one are smaller and easier to handle. That's key. Whatever you feel you have the most control with.
http://www.*.com
Last edited by Jon; 07-11-2006 at 03:40 PM. Reason: Advertising. Please see business posting policy at: http://www.hotrodders.com/help/board/business.html .
Old 07-11-2006, 04:46 PM
35WINDOW's Avatar
Last journal entry: Dash Mock-up
I had the same questions when I started my Project, and after buying about all of the Tools listed, I find I use the Cutoff wheel the least (I started out using it the most). The reason? I have a hard time controlling it on finish cuts, which is amazing because you watch someone like Foose cut a perfectly round circle on a freshly painted hood! I will double up my cutoff Discs and take down a Weld with one (does it fast, but keep control of it!). If I make a patch panel, and it's a relatively straight cut, I use my Kett metal shears (pretty fast, nice edge). If I have to make a more complex cut, I use a electric Nibbler (from HF). It is surprisingly good, but slower. I have used a power Hacksaw to install ready made panels by clamping them to the surface, angling the blade 45 degrees and cutting the edge, and almost have to not grind it, just weld it. I also have about every version of Metal Shears (Wiss brand-I like 'em), and I use them for finish cuts (a lot of times they give me the most control). As far as a Plasma cutter, I have one at work, and I agree with kenseth-nice, fast, relatively clean cut, but not always for everything, and it's a little pricey if you are on a budget. I have also used a Air Chisel, but for me it doesn't always leave a great, undistorted cut.
I would also recommend looking into a 4 1/2 electric Grinder (I like Milwaukee paddle switch) with Flap Discs (40 grit) for taking welds down relatively close, then I use 3" Roloc Discs (36 grit) to finish grinding Welds.
If I had to pick just one? I would say the Nibbler (cheap, does clean cuts, corners), and did I say it's cheap?
Old 07-11-2006, 05:33 PM
Wiki Edits: 31
for cutting sheet steel, I break out my HF air body saw or 3" cut off tool, for grinding welds, I break out my die grinder with a 3M brown rollock disc on it, works great
Old 07-12-2006, 03:49 PM
scrot's Avatar
I have to agree with matt and Badbob. The thin blade of the body airsaw can cut very tight corners and doesn't leave a big kerf like the cutting wheel. The only problem is that the blades that come with the saw are made out of extremely soft metal. I'm not kidding--I can cut only 18" of sheetmetal before the teeth are completely worn down! Fortunately I found some Bluemold brand of blades at Home Depot. They should last longer than the other blades.
[IMG]saw[/IMG]
Old 07-12-2006, 04:06 PM
Wiki Edits: 31
yep, my first blade wore out quickly when cutting 12ga, havn't bothered changing it. got 5 blades I think with the saw.
Old 07-12-2006, 09:42 PM
Blades, I use a Bluepoint airsaw that has lasted for 6 years now, the two Ingersol Rand saws I had before that only lasted 1year at best. I don't buy airsaw blades, instead I buy packages of regular hacksaw blades and trim them to the length and width I need for the airsaw. Some saws use regular hacksaw type blades like mine while others have a dowel pin and need the regular airsaw blades. Hacksaw blades are cheap and the higher quality ones last quite awhile. Bob
Old 07-12-2006, 10:00 PM
Wiki Edits: 31
I think, and I'm not 100% certine but to my knowladge Bluepoint is a snap on company now, and snap on rebadges IR air tools for themselves, that being said, your Bluepoint airsaw may very well be a rebadged IR saw. I like IR stuff, top notch in my book.
Old 07-14-2006, 12:46 PM
cab cab is offline
Thanks Guys - excellent feedback. Hadn't ever heard of the body saw before now. Looks like I'll be buying at least a couple of these tools.
Old 07-15-2006, 05:50 PM
Well..
I work on aircraft bodies (which is just aluminum sheet) for the air force and when we want a nice cut with quickness, we use the recriprocating saw (body saw) as well. Nice clean cut, fast, and relatively easy to use at any level.
Old 07-15-2006, 06:28 PM
Opinions?
Thanks,
Chris
Chris
When cutting for patching I usally use a 4 " grinder, there are some really slim discs on the market lately, something like 0.8 mm, and flexibel. I bought some but have not tried it out yet. 0.8 is what i wold keep as a distance when welding 1.0mm sheet-metal, sorry for the metric.
Now, I have a 4" grinder that I modified 20 years ago by conecting a speed-adjusting trigger? (language-problem?)
This modified tool is SO VERY USEFUL WHILE WORKING ON SHEETMETAL. At slow speed I use it for taking away the paint at an edge that should be welded, and not loose very much metal, I even use it in tight areas without protection cover to gain access. Now dont try this at home, he-he.
I have found a need for very slim cuttings, for example when you have to cut away a piece that is going to be welded back again. In this case I use an air-grinder?, 3.2 mm shaft and a laboratory dentists cutting wheel. aviable down to 0.15 mm thickness.This is TOO slim for welding!!!.
I just hope I inspired you to research for the possible cutting tools. And to answer your qustion. a regular 4" grinder will do the job you specified.
Svenne
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Chop and channeling. how to....? baugh353 Body - Exterior 15 02-07-2006 07:21 AM
Tip of the day #13 MARTINSR Body - Exterior 6 12-24-2005 03:09 PM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 12:21 PM
