what do you use to get paint out of the can - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2013, 07:25 AM
Last journal entry: Still running strong
Just curious, what do you use to get paint from the can to a mixing cup. I've been using a 2 oz. dipper thing that I found in a weight gaining powder container. I don't like to pore it, gets all over everything. I've cleaned that dipper 4 dozen times with lacquer thinner, doesn't seem to hurt it.
Old 07-03-2013, 11:16 AM
evolvo's Avatar
Mixing Mate 10-091 Quart Size Paint Can Lid - Amazon.com Mixing Mate 10-091 Quart Size Paint Can Lid - Amazon.com
Scroll down the page, they have Gallon size, too!
I've used these, they work really well.
Old 07-03-2013, 11:36 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
evolvo,
Thank you for that Link, I just ordered two!
Old 07-03-2013, 11:50 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
A piece of 1.5" tape works best for me.
Nothing to clean, except the groove before attaching it.
Old 07-03-2013, 12:14 PM
I learned this trick right here on the forum. Can't believe I had never thought of it but it works really well. All of the gadgets I have come up with are more trouble than they are worth to clean.
John
Old 07-03-2013, 12:47 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Drill or punch a 1/8 hole in the lip grove of can ,the paint will drain back in to can does not effect seal , no splatter when replacing lid ,I also put a sheet of plastic film under lid before sealing ,makes it much easier to remove lid for next usem
Old 07-03-2013, 01:35 PM
jcclark's Avatar
The Penny Pincher
Originally Posted by 496CHEVY3100 View Post
Drill or punch a 1/8 hole in the lip grove of can m
I used to do that, but every time I shook the can, the
groove filled up with paint.
Old 07-03-2013, 01:53 PM
Built Not Bought
did you use the plastic I use two holes in all of mine with no leaks.might br a difference in can ,??
Old 07-03-2013, 06:44 PM
cyclopsblown34's Avatar
Colorsanding painter
I use the method JC Clark posted. I used to punch the hole in the groove til I learned his trick. It is much cleaner as the paint pours off the crisp edge of the tape and not down the edge of the can.
Old 07-03-2013, 06:52 PM
Built Not Bought
I also use the tape to pour to paint into strainer .the hole is to let the paint in the lip drain back into can to stop splatter when replacing lid.
Old 07-03-2013, 07:52 PM
mitmaks's Avatar
Last journal entry: Grille
I was at local hardware store and saw these, they work great. Available for gallons or quarts
Shop Encore Plastics Paint Stretcher Spout at Lowes.com
Old 07-03-2013, 08:17 PM
evolvo's Avatar
I have a couple of one's similar to the ones I posted. I got mine from my local paint jobber (Wesco). His don't have a crank handle like the Amazon ones do, his have a small cross bar that hook to his mixing machine. These are what he uses to mix his batches of paint. I use a cordless drill with a T fitting to stir the paint. They are sealed from outside air when closed, they don't drip at all, they stir the paint from the very bottom of the can so the mix stays consistent. They are easy to clean if you get a clean empty can and put in some thinner, stir, shake remove and dry. Do it again if it needs it, ez,pz! There's nothing better IMHO!!!
Old 07-03-2013, 08:50 PM
life is a temporary assignment
I just pop two holes in the lid... When done put a piece of tape over the holes...No mess..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
cyclopsblown34 (07-03-2013)
Old 07-03-2013, 09:11 PM
I have used those and they work but they are a pain to clean up and if you don't clean them well, you will get dried paint "crumbs" in your new paint. To me they were more trouble than they were worth.
Still like the tape that I can just throw away.
John
Old 07-04-2013, 12:46 AM
Built Not Bought
is it hard to stir the paiy thru the holes .LOL LOL
Will paint peel if I only paint firewall? Should I wait to paint whole cab? jsm1847 Body - Exterior 10 07-10-2012 07:28 AM
The ultimate budget paint job thread /w pics (rustoleum paint) Project89 Hotrodding Basics 130 04-24-2012 01:19 AM
What type of paint sticks to sanded, pre-existing paint? Rockworthy Body - Exterior 19 01-25-2011 11:41 PM
prepping my car now for paint. questions on how far to sand existing paint ((sr)) kelly Body - Exterior 3 07-15-2009 12:49 PM
