What do your cars sound like? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2012, 12:17 AM
painted jester's Avatar
Last journal entry: 383 BLAH, BLAH.
It was cloudy today and drizzly but I needed to sweep the Garage and spruce up so I pulled the car out and let it run to warm up! And my daughter took this with a phone ( Wow with a phone) Who would guess Movies on a phone! She put it on u tube( embarrassing the cars not done) The picture and sound aren't great! But it made me think what do your cars sound like? It would be cool to hear em
Jester
1977 Corvette - YouTube
Old 10-23-2012, 01:43 AM
And the answer is no ! Its not a thumper cam, Its an old General Kinetiks from My old B-Gasser I covered in grease in 1973 and wrapped in newspaper and put away till 3 years ago and installed it in the 302 (a De-stroked 350 )!
Jester
Old 10-23-2012, 03:41 AM
67Mustang Al.'s Avatar
Not a bad effort with the phone and sounds great at idle. Howz it at 5000
Al
Old 10-23-2012, 06:20 AM
wretched ratchet's Avatar
one full turn after it squeeks
OK, if you promise not to laugh
Old 10-23-2012, 07:10 AM
jdsaengine's Avatar
This is mine, not sure if the link is still working, but here goes
32 Ford - YouTube
Old 10-23-2012, 08:54 AM
The engine that came with the body for my current project.
Old 10-23-2012, 02:04 PM
Al
I don't know I'm always in the car at 5000 driving! LOL and just reving it to 5000 isnt the same without the load on it! But everyone else says it sounds wicked uncapped at 7,000+ rpm at the strip! On the street its caped and flowing through Summit welded racing mufflers! When I open the dumps the exhaust is flowing mostly out the 18" x 3" dumps but some still flows out through the mufflers! I ran a comp #305H but was never happy with it so I put in the old G.K. custom grind and it woke the little 302 up.
In the B-Gasser the cam red-lined the engine at 8700 rpm in 1973 in a 283. I could rev over 9000 Rpm but my best times came when shifting at around 8500. my valve springs were around 500 Lb. and I had a lot of valve train ware!! The springs on the Vette are around 375 Lb. so it floats earlier I cant get the higher rpm but my valve train lasts longer.
I built another 302 for my wife 79 Camaro project LOL Its pretty !!! Mines not ! I put the Comp #305H cam in it. I built her's old skool 60s style
http://www.hotrodders.com/forum/atta...1&d=1351022033
Jester
ID:	68553   Click image for larger version
Name:	Copy of PICT0016.JPG
ID:	68554   Click image for larger version
Old 10-23-2012, 02:09 PM
[QUOTE=jdsaengine;1602217]This is mine, not sure if the link is still working, but here goes
The link works fine you need to give details (cam and mufflers)! Sound great!
Jester
Old 10-23-2012, 02:13 PM
[QUOTE=wretched ratchet;1602198]OK, if you promise not to laugh
Nothing to laugh about the 6's held their own and blew away many V8's, Gas class's were full of 6's I ran a J-Gas stump puller in the 60's!
Jester
Old 10-23-2012, 02:27 PM
327NUT's Avatar
Mine can be seen on youtube...507" Cadillac dyno session,
Old 10-23-2012, 04:11 PM
Found it!!
Jester
Old 10-23-2012, 04:36 PM
Jester
That Pink block is outstanding. You are definitely racking up the brownie points there. I like the "Hamburger" sticker on the sump.
Al.
Old 10-23-2012, 06:46 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Here's my shop truck shortly after I installed the tail pipes. The wife is operating the go pedal, I'm doing my best Francis Ford Copolla technique with the camera
350 Small Block Chevy with long tube headers, 28 inch Cherry Bomb glass pack mufflers and 2-1/2" dia. full length tail pipes.
Old 10-23-2012, 07:25 PM
jdsaengine's Avatar
[quote=painted jester;1602355]
Jester
Its a 305 chev out of an 86 pickup, with comp. cam, going thru Flowmasters. Goes pretty good and gets 20-21 mpg
Old 10-23-2012, 08:00 PM
Al.
It was painted Red My wife wanted the plurple! She bought the VHT purple engine paint from Speedway! Her Camaro will be painted "Plum Crazy" and shes got purple dice door locks, an valve stem caps and fuzzy dice for the mirror! LOL
Jester
Designer/cadcam sound deadening kits for cars edw47 Introduce Yourself 1 01-18-2011 11:14 AM
Clicking sound turned into a grinding sound. Chevy350Sb Suspension - Brakes - Steering 2 11-19-2009 12:00 PM
Do fuel injected cars sound different than carbed cars ???? Calderone Engine 12 08-08-2008 11:23 AM
Sound clips of gear drives? Vids of cars w/ gear drives? Magnum Rockwilder Engine 12 08-14-2005 06:14 PM
Poll... on the sound of solid VS hyd cam sound. Blown72Camaro Engine 12 05-28-2004 05:56 PM
