What does everyone do about Fuel Tank Vent Smell? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2012, 03:18 PM
35WINDOW's Avatar
Last journal entry: Engine!
Not quite certain how to title this Thread, but I am in the throes of upgrading my Fuel System and thought (after reading some Threads here) about not wanting a "fuel smell" in my garage when my Car sits, so,
I have thought of the Charcoal Cannister thing (and if I used this option I don't know who's/what Cannister to use), but my understanding is that you have to hook it up to your Intake, which I cannot do given my configuration-if I'm wrong about this, please let me know!
I've also heard about using a shut-off valve, which I can, but I'd hate to forget to open it!
What is everyone using on their non-factory build to deal with this? There has to be a trick here that I don't know-
Old 06-26-2012, 03:21 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
installing the vent to the charcoal canister so the tank vents through the canister will help..use anyone you can find at the pick a-part..factory install will run a hose from the canister to the intake but oh well maybe we can't do that..
Sam
Old 06-26-2012, 03:25 PM
da34guy's Avatar
Put a PCV on the vent line
Old 06-27-2012, 05:59 AM
Irelands child's Avatar
Craig - I ran into that problem when I first put gas in my car. I had suggestions from fuggedaboutit, it's a hot rod to install the GM vacuum canister/return system. What I ended up doing is mounting the roll over/vent valve on a 4-5 inch extension on the tank top which raises it well above the fuel tank level. I then ran a piece of fuel hose as high as possible in the trunk behind the upholstery with a couple of 360* loops and then out of the car body and bracketed to rear fender brace with another loop - all out of sight. Is it 100% - dang close. Any condensate that settles in the line loops is then sucked back into the tank when running as I'm using an unvented gas cap.
Also - one drop of gas will stink up a shop and if the system has the tiniest leak, tough sometimes to find, it will be a problem as well - and I went through that too
Dave W
Old 06-27-2012, 06:22 AM
35WINDOW's Avatar
Sam
Sam,
Thank you for your suggestion, I will look into that, and Iwonder if those Cannisters rely on the Intake vacuum to draw in the vapor?
Old 06-27-2012, 06:23 AM
35WINDOW's Avatar
In thinking about this one, isn't a PCV essentially a one way valve? Doesn't a Fuel Tank need to be able to both expand and contract?
Old 06-27-2012, 06:31 AM
35WINDOW's Avatar
Dave W
Dave,
Thank you very much for the long explanation, and an elegant solution that must have taken some brain power as I would have not thought of that!
In my case the Tank is below the Floor, so I will have to do some thinking on how to accomplish it, although it does sound like a great idea! I am going to run hard line all the way (except for a couple of small pieces in the engine bay) to try and stop any "leaks"-
Hmmm, maybe I can do both?
Old 06-27-2012, 12:23 PM
F-BIRD'88's Avatar
Yada Yada Yada
Install cross flow vent(S) in the garage. Possibly with a automatic venting fan.
No more gas fume buildup. less dampness. Cooler in summer.
You do not want a air tight garage. Especially if the cars sit for long periods of time.
Old 06-27-2012, 03:04 PM
1971BB427's Avatar
When I built my gasser I vented the fuel cell with hard line and did a 360 degree loop right at the tank to avoid the smell from exiting the tank. I also added a simple fuel filter to the end of the line to keep bugs from crawling into the vent line, and further contain smells.
I don't have any fuel smell issues even when the car sits for weeks in the garage.
Old 06-27-2012, 04:00 PM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by 35WINDOW
Sam,
The use the vacuum for testing. In most cars the evap is tested by pulling a vacuum on the tank and seeing how long it holds. The vacuum is also used to purge the canister which I dont think would be needed in your case
Chet
fuel tank vent line whojohnjones Engine 0 04-17-2011 12:12 PM
Fuel Stink - How to Vent Fuel Tank for Chevy 350 TPI Engine kbuhagiar Engine 5 08-18-2010 07:54 AM
Fuel tank vent plumbing scrimshaw General Rodding Tech 8 05-17-2009 10:01 AM
Fuel Tank Vent dodgetruck General Rodding Tech 4 07-13-2006 05:57 PM
fuel tank vent question william27103 Engine 6 04-23-2006 04:54 PM
