-   -   What does this flywheel fit (http://www.hotrodders.com/forum/what-does-flywheel-fit-221516.html)
split63 07-10-2012 12:41 PM
Hi,
Sorry I forgot to give the Numbers in the previous post!!
#3789733 with a date code of A 2 8. I'm not sure but i think i removed it from a 68 corvette many many years ago.
Thanks for any help.
66GMC 07-10-2012 12:58 PM
I found a thread on a corvette forumcorvetteforum and it sounds correct. Your date code translates to Jan 2 , 1968 (I think)
eloc431962 07-10-2012 01:07 PM
Originally Posted by split63 (Post 1572555)
Hi,
#3789733 A 2 8, should be a big block manual trans flywheel from January 2 1968. JMO
Cole
:pimp:
ericnova72 07-10-2012 01:16 PM
Cole
:pimp:
Actually, it will fit a neutral balance small block (265-350, but not the external balance 400) also, since all Big Block Chevys (366/396/427) were neutral balance until the 1970 intoduction of the external balance 454.
Its just an 11" clutch nuetral balance flywheel, fits SBC and BBC except the external balance engines.
eloc431962 07-10-2012 04:23 PM
Good call Eric,:thumbup: good to see you my friend.:D:cool:
Cole
:pimp:
cobalt327 07-10-2012 05:48 PM
Hi,
The casting number is in your earlier post- http://www.hotrodders.com/forum/what...ml#post1572549;)
split63 07-11-2012 12:35 PM
Thanks for the info!
split63 07-11-2012 12:47 PM
Thanks, i figured out how to edit!
