What does this flywheel fit - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2012, 12:41 PM
Hi,
Sorry I forgot to give the Numbers in the previous post!!
#3789733 with a date code of A 2 8. I'm not sure but i think i removed it from a 68 corvette many many years ago.
Thanks for any help.
Old 07-10-2012, 12:58 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I found a thread on a corvette forumcorvetteforum and it sounds correct. Your date code translates to Jan 2 , 1968 (I think)
The Following User Says Thank You to 66GMC For This Useful Post:
split63 (07-10-2012)
Old 07-10-2012, 01:07 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by split63 View Post
Hi,
#3789733 A 2 8, should be a big block manual trans flywheel from January 2 1968. JMO
Cole
The Following User Says Thank You to eloc431962 For This Useful Post:
Old 07-10-2012, 01:16 PM
ericnova72's Avatar
More for Less Racer
Cole
Actually, it will fit a neutral balance small block (265-350, but not the external balance 400) also, since all Big Block Chevys (366/396/427) were neutral balance until the 1970 intoduction of the external balance 454.
Its just an 11" clutch nuetral balance flywheel, fits SBC and BBC except the external balance engines.
The Following 2 Users Say Thank You to ericnova72 For This Useful Post:
eloc431962 (07-10-2012), split63 (07-11-2012)
Old 07-10-2012, 04:23 PM
eloc431962's Avatar
Wiki Edits: 37
Good call Eric, good to see you my friend.
Cole
Old 07-10-2012, 05:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Hi,
The casting number is in your earlier post- what does this flywheel fit?
Old 07-11-2012, 12:35 PM
Thanks for the info!
Old 07-11-2012, 12:47 PM
Thanks, i figured out how to edit!
what does this flywheel fit? split63 Transmission - Rearend 3 07-10-2012 05:15 PM
300 L-6 flywheel, fit any v-8 engines ? fast68 Engine 14 04-03-2009 06:38 PM
350 starter, alternator, and flywheel fit a 283 BIGWISEXY Engine 4 02-04-2009 08:38 PM
1986 Iroc 5 spd Flywheel and Clutch > Fit's 4.3?? boneyard Buick Transmission - Rearend 7 11-11-2006 08:10 PM
1986 Iroc 5 spd Flywheel and Clutch > Fit's 4.3?? boneyard Buick Engine 3 11-06-2006 08:11 PM
