What does a good 9 inch rear cost? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2012, 06:50 PM
Buckeye Bob's Avatar
I was thinking about putting a 9 inch rear in my51 f1 it has a 302/aod &
the original 51 rear with 3:73 gears in it.i might be able to pick up this old
65 ford f100 with a 352 (i think that is what it is) & 3 on the tree with a
9 inch rear for about $350-$400-the truck body is shot it has been sitting
for 3 yrs
Old 10-21-2012, 08:13 PM
BOBCRMAN@aol.com's Avatar
Around here, you could pull the rear end and sell the rest for $350.00 scrap.
Old 10-22-2012, 06:20 AM
big gear head's Avatar
High Performance Rear Ends
Depends on what you call a good 9 inch. A good 9 inch to me would be around $2800. That gets you a nodular case with a Daytona pinion housing, 31 spline axles, a Dura Grip or Detroit Locker and a new heavy duty housing. Almost any 9 inch that you get from a salvage yard or out of something old is going to need a complete rebuild, and it's probably going to have 28 spline axles and a standard differential. Figure on at least $400 for the rebuld and another $900 or more to replace the axles and differential.
Old 10-22-2012, 06:35 AM
Last journal entry: was hoping for better than this
thats funny, I got a 9" out of a truck with a locker and 3.90'ish gears for 75 bucks
and drum to drum..
more than good enough for most builds..
Old 10-22-2012, 06:42 AM
Great buy. Yea, like you said, most people can get by with something stock. I like big blocks, 4 speeds and big tires, so stock isn't going to hold up to what I would put it through.
How much should it cost to fix a howling rear end? jerellem Transmission - Rearend 8 07-23-2009 01:12 PM
Welding a rear brace on a ford 9 inch rear end makaveli200369 Transmission - Rearend 4 07-02-2009 10:19 AM
New big inch rims vs good ole 15" 78 monte Hotrodders' Lounge 23 10-13-2007 01:11 AM
Rear end installation cost? 69ChevelleAddict Transmission - Rearend 6 07-13-2005 10:53 AM
Ford 9 inch.. good or bad? freerider99 Transmission - Rearend 4 07-17-2004 09:21 AM
