Usally gm makes the heads and blocks are made by many manufactures. Brodix and dart can also get you heads.
They are LS based now will straight port design. You cna buy the heads but they are for 4.1 ls short stroke bores not normal 350 style engines. If you want a nascar or nascar style engine you can get pontiac performance heads from gm performance or you can go 18 degree heads that are also ery good. 18 degree heads and intake will build one hell of a gen one engine. 800 hp is normal number for 18 degree heads. Sb2 is also easy to get for a late block but will cost a pile of cash over the gen one upgrades. But with 12 degree valves they will make even more power with less rpm and better flow. Here is a link to gm sight for race heads. http://www.gmpartsdirect.com/perform...CATID=671.html |
The other manufacturers also have their own race-only NASCAR engines. |
Looks like current R09 and R07 are what they have used the last few years. The ls7 used to make the r07 is a 4.1 to 4.4 bore block. And the newer blocks all appear to be 4.5 bore for the r09. This is the same type engine used in the pro touring car corvette. The way they are built is pretty sweet you can buy this stockish form but a ls9 is a 2013 427 block punched out way over tolerence. Kinda of hard to think you want to build one of these. You can buy the blocks with proper bore but they are not cheap either and you still can build the 427+ cubes with that block in a short stroke form that would make insane power. So no real reason to pursue the 358 nascar spec engines. There are some much more interesting combos with those borse and valve sizes to be made. A street drivable 800 hp without a turbo is no problem. The heads are amazing and will never be the limiting factor of making big power. The biggest limiting factor would be the crank block and rods. And they are forged cast is not sold in those sizes.
What I have seen in NASCAR is rough forgings for custom one of a kind in house builds.
SB2.2 heads are AMAZING. The flow numbers are incredible.
They are made for hi-rpm. And yes, they have been around a long time. I seen a mid 90's Camaro with a 394cid SB2.2-head motor just devastate a 70 Nova with a 555cid Brodix-headed roller motor. The Nova had NO chance against the Camaro. I'm talking like a 15 car-length difference in the 1/4 mile. Neither car was running power-adders. The Camaro had a single 5" exhaust pipe out the back. It was one sick ride. |
they are about 40k to lease give or take.. as long as you bring it back after the race in one piece even if you get a parts list.. each team that has an engine program, gets the parts raw.. and put their own magic in them.. heads on a hendrick car will not look like a RCR head in the ports or chamber.. at this level.. every little tiny thing makes a difference.. when and if you see an RCR head on those used racing part sites. they've already move past that tech.. the ro7 that I has the honor of helping see built.. every port is different, the cam lobes are different for every cyl.. all to get as equal a/f to every cyl.. the parts list is the easy part, the labor put into everything is the difference.. Last edited by gearheadslife; 12-15-2012 at 10:17 PM. |
Nothing on the R07 translates to the LSx engine. Nothing fits. Not the heads, crank, cam, nothing worth mentioning. GM says
The bore is not 4.5", the bore centers are at 4.5". Big difference- NASCAR has a bore diameter limit at about 4.185". |
To lease an engine from Hendricks for 1 race, capable of qualifying on time, cost about $50k 6 years ago. For that money you got a tuner and a mechanic for the weekend. I would guess that price has doubled by now.
Seen these on ebay and figured you guys would like to take a look.
Chevy R07 Aluminum Cylinder Heads Set 99 Complete NASCAR Arca Nationwide NHRA | eBay They look nice i think they should fit a 6.0 truck engine. |
NASCAR provides sealed controllers to the teams not to be altered in any way for the EFI systems and is unavailable to the general public.
| My one and ONLY NASCAR Rant ! | wretched ratchet | Off-Topic | 8 | 03-08-2010 06:21 PM |
| NASCAR exhaust | runn141 | Hotrodders' Lounge | 6 | 02-08-2009 09:31 PM |
| Nascar rods | jcpts | Engine | 10 | 07-30-2007 07:36 AM |
| Nascar Nnitro | trees | Off-Topic | 2 | 02-19-2007 09:52 AM |
| NASCAR....Martinsville | poncho62 | Hotrodders' Lounge | 15 | 04-18-2004 06:46 PM |
