what does a speed censor do? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2005, 06:08 PM
ok i have an 89 dodge dakota 3.9 v6 with automatic trans i bought the truck with a bad tranny it was a 4speed automatic with overdrive i couldnt find one of them trannys so i bought a 3 speed automatic. now on the old tranny it didnt have a speed censor cause it was broken off but the new tranny does have it there is a 2 wire plug that is suppose to plug into this thing and it looks like you can screw a cable on the end of it too for the speedometer or the cruise or something so can anyone tell me what this speed censor does and does it have to be hooked up for the tranny to shift and work right thanks for any help and if you need more info let me know
Old 06-15-2005, 06:27 PM
woodz428's Avatar
Troll Hunter
Most speed sensors are used for cruise control or speedo (electronic) or both. A speed sensor that has a hook-up for a cable was probably used on a vehicle with a cruise and cable driven speedo. I have one on a mid 80's Fox car and one of an earlier one. They are identical even though the later one had an eledtronic speedo....it just has a cap over the drive hole, held in by a circlip.
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 08:44 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
Th350 to 4 speed auto conversion Bandit1980 Transmission - Rearend 3 12-29-2004 08:41 PM
saginaw 3 speed od conversion slingslingbinks Transmission - Rearend 4 10-06-2003 02:07 PM
