Re: what does the square, and the triangle mean on a cloyes gear set
Originally posted by bullheimer
my crank gear is on the square. if that's for low end, i like it, if it's for advanced i will have to take it off. i dont want to . all i know is the circle is for straight up and it aint on the circle.
Here's a link for you.
Timing Chain Install
As you can see, setting the crank sprocket on the square RETARDS the timing. This will give you LESS bottom end and more top end. NOT what you want.
